'67/'68 Clutch & Brake Pedal Bracket - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 15th, 12, 11:36 PM Thread Starter
Merv
I have a '68 Camaro and need a Clutch & Brake pedal BRACKET(#3918739)Assembly. It's the BRACKET that bolts up under the dash, has the brake & clutch pedals pivoting off it, and has 4 studs(3/8"-16) that stick through the firewall(brake master cylinder bolts up to studs). Where do I find one or who makes such a BRACKET? Is the BRACKET still available through GM?
binky3 is offline
post #2 of 4 (permalink) Old Feb 16th, 12, 09:30 AM
steve
Re: '67/'68 Clutch & Brake Pedal Bracket
I was looking for the same a few months back and I could not find anyone who made a replacement or who had one so I repaired mine and moved on. If you dont have one at all and not interested in keeping it to original parts you could make your own pretty easily.
sflippen is offline
post #3 of 4 (permalink) Old Feb 16th, 12, 11:26 AM
They are being reproduced now. Nice used ones, often with pedals, come up on ebay quite a bit. Make sure you do not get a 69 bracket.
http://www.heartbeatcitycamaro.com/s...ssembly-67-68/
Eric
Eric Kammerer is offline
post #4 of 4 (permalink) Old Feb 16th, 12, 11:33 AM
nice used one at great price here on classifieds.
http://www.camaros.net/classifieds/s...ct=48391&cat=8
Eric
Tags
clutch brake bracket 1968
Human Verification
