1969 Z28 30-30 Camshaft? - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 15th, 12, 01:34 AM Thread Starter
Eddie
Hi,
'69 Z28 car. I want to know if I have the Z28 cam or not.
I have no history on the engine, only what I can see from codes and visual inspection. The camshaft is definately mechanical (I adjusted the noisy lifters). At 950rpm idle it is pulling 15-17 inches of mercury. Would that rule out it being the 30-30 camshaft?
The engine runs strong and has been detailed as a Z28 (4053 carb, Winters inlet, cast manifolds with smog pump) so would seem strange they would not use one as so much else is correct.
Other info-
From a clutch change the crank has the pie crust cut out so I assume it is a 302. The block is 3970010 (but that could go either way and cannot trust the block DZ stamp). Heads are 186 (date coded January 1970).
Thx
Eddie
EddieCross is offline
post #2 of 7 (permalink) Old Jul 15th, 12, 05:31 AM
Tim
Re: 1969 Z28 30-30 Camshaft?
Hey Eddie, welcome - and great choice of car! What part of W London are you in? I used to live in Hammersmith/Shepherd's Bush area, loved it! Now back to your question:
Short of pulling the cam, you'd need to be familiar with using dial gauges and a degree wheel to detemine approximate cam specs (lift, duration etc); Measuring lift with solid lifters will be more accurate than hydraulic lifters, but if cam lobes, pushrods etc are worn and unevenly so, you won't get accurate readings - but should be close enough to determine if you are in the right ballpark. Bear in mind also that even if the engine still has a Z/28 cam, it could be the 140 off-road version, so be prepared to check your findings against factory specs of this too.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Raced in E/MP at Lions in LA. Now restoring!
ZLP955 is offline
post #3 of 7 (permalink) Old Jul 15th, 12, 07:22 AM Thread Starter
Eddie
Further West- Egham, near Heathrow.
Many thanks for the response.
Degree wheel is going to be tricky with the engine in. I'll have a look and see if it could work in situ. I have wheel, dial gauge and stand and have done this before on engine rebuilds so it's just setting up.
but....any posts that I have found so far seem to put the idle vacuum at around 9-10 for these cams. Just wondering if I can rule out the 30-30 or 140 at this stage or if there is still hope!
Cheers
Eddie
post #4 of 7 (permalink) Old Jul 15th, 12, 08:46 AM
Jake-68's rule
Or you can place masking tape on the circumference of the harmonic balancer and use the existing TDC and 10° scale marking the tape every 10°, or get at timing tape for the correct diameter of the h/balancer and measure the degrees of valve action and compare to documented lists of camshafts for vlave opening/closing and valve lift.
I suspect, like you, there is a milder camshaft since 15-17 inches of vacuum.
Give a man a rescued dog for the health of both their souls.
'With age comes wisdom, but then wisdom ages you even more.'
CUBS - 2016 World Series Champions
post #5 of 7 (permalink) Old Jul 15th, 12, 08:56 AM
DjD
DjD's Avatar
Maybe an LT1 cam...
...Dennis
DjD is offline
post #6 of 7 (permalink) Old Jul 15th, 12, 09:13 AM
Alan
I think the 30-30 cam will only give you 6-9" of vacuum on a good day. That's why it requires the B25 vac advance can for the distributor.
alan
alanrw is offline
post #7 of 7 (permalink) Old Jul 15th, 12, 10:23 AM Thread Starter
Eddie
I'll probably leave it until it's time to pull the engine and then strip and id every part. If the reciprocating parts are 302 then I want the 30-30 or 140 back in it. I didn't buy this car for an easy life! Just installed the B28 distributor cannister so I'm prepared.
Thanks again
Eddie
Human Verification
