69 cowl induction throttle arm - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 14th, 13, 05:20 PM Thread Starter
Rodney
Hey guys, I have an original 6 cyl car that now has a SB 400. I bought all the components to make the cowl induction hood operational but I am not sure how the throttle arm attaches to the accelerator pedal. I am currently running a throttle cable and the accelerator rod that goes through the support bracket mounted on the firewall is not long enough to mount the throttle arm to. It is barely long enough to put the E-Clip on. Do I need a different accelerator setup or will this even work with a cable setup? I'm stumped on how to attach this arm to the pedal.
Rodney21 is offline
post #2 of 13 (permalink) Old Feb 14th, 13, 07:42 PM
Steiner
Re: 69 cowl induction throttle arm
Six cylinder and V8 have different throttle assemblies. Not sure what all you've got now but here's a list of different setups.
http://www.rickscamaros.com/catalogs...=12&q=rod+thru
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 13 (permalink) Old Feb 14th, 13, 08:12 PM Thread Starter
Rodney
Here are pics under the dash and of the firewall.
Rodney21 is offline
post #4 of 13 (permalink) Old Feb 14th, 13, 08:21 PM Thread Starter
Rodney
I don't have enough space to post the Firewall pic
Rodney21 is offline
post #5 of 13 (permalink) Old Feb 14th, 13, 08:38 PM Thread Starter
Rodney
Firewall
Rodney21 is offline
post #6 of 13 (permalink) Old Feb 14th, 13, 08:42 PM
Steiner
I think you may only need the $34 thru firewall accelerator rod for a V8.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 13 (permalink) Old Feb 14th, 13, 08:48 PM Thread Starter
Rodney
Thanks. That was what I was thinking but I'll need to weld the cable arm onto it.
Rodney21 is offline
post #8 of 13 (permalink) Old Feb 14th, 13, 08:52 PM Thread Starter
Rodney
Under dash
Rodney21 is offline
post #9 of 13 (permalink) Old Feb 14th, 13, 09:05 PM
Steiner
You shouldn't need to weld anything. The new throttle arm (under hood) just clamps to the new accelerator rod. Then you need the linkage and little bushings for a few bucks to connect between the carb and new throttle arm. You will no longer use a cable.
If you wanted to retain the six cylinder accelerator rod and cable operated throttle, you could use a nitrous throttle switch mounted inside the car instead of the one that mounts using the new cowl induction throttle arm, and not use the new arm at all. All you're looking for is a switch to make under full throttle.
'69 Camaro
500hp/538lbft
Steiner is offline
post #10 of 13 (permalink) Old Feb 14th, 13, 09:25 PM Thread Starter
Rodney
I appreciate all the help. I've looked through a bunch of catalogs and ebay and can't seem to find this linkage.
Rodney21 is offline
post #11 of 13 (permalink) Old Feb 14th, 13, 09:42 PM
Ed
gas pedal and arm for cowl hood
http://www.ebay.com/itm/1969-Camaro-...263579&vxp=mtr
cowl switch
http://www.ebay.com/itm/1969-Camaro-...c92baf&vxp=mtr
You'll also need linkage from arm to carb, groment, wire harness and relay. I'm sure someone has this in a kit, just not finding one at the moment.
freezined is offline
post #12 of 13 (permalink) Old Feb 14th, 13, 09:51 PM Thread Starter
Rodney
Thank you. I've got all the cowl induction parts. I was just missing connecting the throttle arm to the carb. I've for an edelbrock carb and intake so I'll have to figure out how to make this linkage work. I really appreciate all of your help.
Rodney21 is offline
post #13 of 13 (permalink) Old Feb 14th, 13, 10:04 PM
Steiner
Here is the grommet that goes in the throttle arm. You may need two, one in the arm and one in the carb.
http://www.rickscamaros.com/camaro-c...1967-1969.html
I'm using this for a throttle linkage but my throttle setup is similar to a Holley. There are universal ones as well that you just bend as needed (carefully) although this one can be bent a tad.
http://www.summitracing.com/parts/oe...t/model/camaro
'69 Camaro
500hp/538lbft
Steiner is offline
Human Verification
