Throttle Cable in '67 - BB EFI - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 17th, 01, 10:24 AM Thread Starter
James
I am converting my '67 RS to an EFI Big Block (500") and need to convert to a throttle cable vs. linkage. I know that inline 6's had cables so my question is this: (a) has anyone used an aftermarket or late model setup that they are happy with or (b) where can I get a inline 6 gas pedal assembly (besides a wrecker)? Thanks.
by the way - pictures of the conversion are at http://www.adivanman.homestead.com - I will post as things progress.
James67RS is offline
post #2 of 6 (permalink) Old Aug 17th, 01, 10:47 AM
Early 70's Novas have a cable operated linkage and there are lots of them in the junkyards. It's a bolt in on first gen cars, all that needs to be added is one hole in the firewall that is already pre-positioned.
The Red Beast http://www.geocities.com/casanoc
CarlC is offline
post #3 of 6 (permalink) Old Aug 17th, 01, 11:02 AM
Bret
You can also check out http://www.lokar.com/ if you are looking for something a little trick!
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
bretcopsey is offline
post #4 of 6 (permalink) Old Aug 17th, 01, 11:04 AM
Have you looked at Lokars products? They have a bunch of stuff like that, I'm using their throttle cable on my car and it works great.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #5 of 6 (permalink) Old Aug 17th, 01, 11:24 AM
ZZ_430's Avatar
Thumbs up
Yes on the Lokar!..nice stuff!
Don~ ZZ430DropTop Pro-Touring.com DropTop
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #6 of 6 (permalink) Old Aug 17th, 01, 01:57 PM
I just pulled 2 complete throttle cable setups off early Novas at the local pull-n-save for under $10.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
Human Verification
