Block prep for new head gasket - Quick answers appreciated. - Team Camaro Tech
post #1 of 21 (permalink) Old Mar 18th, 17, 07:54 PM Thread Starter
Bruce
I'm going with a steel shim head gasket to increase compression. I know some say no, but it's what was on it for the last 50 years.
Prepping the block - I see the indentations in the block from the sealing rings on the original steel shim head gasket.
How is the top of the block best cleaned, and do I have to worry about those indents on the block??
Edit, tips on cleaning out the crud from the cylinders? I was going to vacuum them out, use a dental pick if needed.
Hope to get the heads back on tomorrow so any quickie answers appreciated.
Coach62 is offline
post #2 of 21 (permalink) Old Mar 19th, 17, 05:15 AM
kevin
Re: Block prep for new head gasket - Quick answers appreciated.
I always stuffed the cylinders with rags and used a razor blade scraper if necessary, air hose or vacuum . then wiped it down with a rag soaked with carb cleaner
I then used plain ol aluminum spray paint to paint the steel head gasket
sound track of my 68 383
flat tire is offline
post #3 of 21 (permalink) Old Mar 19th, 17, 05:46 AM
Spray paint is too thin for me. I use Permatex Indian Head Shellac with brush on block , heads and gasket.
TC # 349
zdld17 is offline
post #4 of 21 (permalink) Old Mar 19th, 17, 07:42 AM
Jake-68's rule
I remove the dowel pins
Then buy a new WD40 can and a NEW Norton honing stone, like you use for your knife sharpening.
Spray decks and heads with WD40 and use the new stone for 'polishing' the decks.
Then install the dowel pins and shim gaskets dry and retorque after break-in if iron heads or wait till to the next day and retorque with alum heads.
Permatex #2 for head bolts.
But, I am not a professional engine builder, but the above has worked for me.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas,' '
CUBS - 2016 World Series Champions
post #5 of 21 (permalink) Old Mar 19th, 17, 12:59 PM
Den
DenRS's Avatar
I used a felpro coated steel shim on my rebuild and it leaked coolant. Your deck surface needs to be smooth enough for it to seal. If your deck surface isn't smooth and flat I'd use another gasket. If you insist on using the steel shim, some people use permatex cooper coat to help seal the gasket.
DenRS is offline
post #6 of 21 (permalink) Old Mar 19th, 17, 01:22 PM
Daryl
1968RallySport's Avatar
Just out of curiosity, what grit stone do you use Everett?
1968RallySport is offline
post #7 of 21 (permalink) Old Mar 19th, 17, 03:17 PM Thread Starter
Bruce
Thanks for the input everyone. Leaking is obviously a concern, but I really wanted the higher compression. I know a lot of people use the copper coating, but Felpro says not to. I've never heard of anyone saying that the copper coating screwed things up for them.
I saw a mechanic on youtube that showed how he uses a flat sanding block, I like that idea, it would knock down any high spots while cleaning everything.
Coach62 is offline
post #8 of 21 (permalink) Old Mar 19th, 17, 03:43 PM
I used Fel-Pro 7733SH1 head gaskets with no paint spraying along with Permatex 2 on all head bolt and intake bolt threads.
Mark 1970 Z28 M22 3.73 Z21 Z87 - Lunati 20120121 Retrofit Roller Cam
Owned: 1968 Z/28 in '74. 1971 Z28 from '75-'77 4-spd
Ordered new Z28's in 1977, 1978 & 1980, all 4-spds.
1970 Z28 owned since 1981
COPO is offline
post #9 of 21 (permalink) Old Mar 19th, 17, 05:32 PM
kevin
maybe a dumb question, but if this is not a bare block, where does the grit go
post #10 of 21 (permalink) Old Mar 19th, 17, 06:20 PM
If the block is on a motor stand, turn the cly head facing the ground and sand, particles should fall to earth. Otherwise plug holes with damp towels and sand. Magnets?
TC # 349
zdld17 is offline
post #11 of 21 (permalink) Old Mar 19th, 17, 08:38 PM
Randy
Use the Victor .026 Head gaskets---you will be alot better off----I tried the .015 steel shim gaskets and both sides seeped---I used a stone with WD-40 on block and heads, also used the copper spray on the gaskets. The Victor gaskets seal alot better and you will never notice the .026 vs .015
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #12 of 21 (permalink) Old Mar 19th, 17, 09:23 PM Thread Starter
Bruce
That is a big concern. I was going to vacuum everything after.
Coach62 is offline
post #13 of 21 (permalink) Old Mar 20th, 17, 06:58 AM
Vega$69's Avatar
I would not go with the shim gasket. The small increase in compression is not worth the risk of the head gasket leaking.
You said you see the indentations from the old head gasket. That's reason #1 not to try a new one unless you deck the block which is next to impossible by hand.
Vega$69 is offline
post #14 of 21 (permalink) Old Mar 20th, 17, 06:50 PM Thread Starter
Bruce
I may do just that. The original plan was use the steel shim (most report excellent results with it) because I was going to go with a hotter cam. I've dialed down the cam, so I guess I can dial down the compression.
Just going by memory here, but it was more than just a small increase in compression. It was going up almost a full point to 10:1.
I may look into the GM performance head gasket, I think they have one about .029 or something like that.
Coach62 is offline
post #15 of 21 (permalink) Old Mar 20th, 17, 07:26 PM
Vega$69's Avatar
The diff in head gasket thickness will not yield a full point on compression. My calculator with a zero deck show 1/3 of a point between a .16 and a .039 head gasket
Vega$69 is offline
Human Verification
