? about pistons - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 22nd, 05, 02:45 PM Thread Starter
Chad
67 Plum's Avatar
? about pistons
I was given a set of GM pistons today.On the top #464664 on the bottom TRW and #508-99.They are flat tops with a single trough valve pocket.Are they forged and what is the application?
67 Plum is offline
post #2 of 3 (permalink) Old Apr 22nd, 05, 05:31 PM
Gary
Re: ? about pistons
Not much to go on there, with GM numbers, but it sounds like an L-82 piston, like they used in the Vette's and Camaro's (which were forged up originally at the TRW foundry for GM). If that's the right one, the TRW #L2417F should be a similar piston. Thanks, Gary
GOSFAST is offline
post #3 of 3 (permalink) Old Apr 22nd, 05, 06:22 PM
Re: ? about pistons
'71-'80 L-82 piston. Gm part#474190. 9:1 comp with 76cc head. Standard bore with pressed pin. Forged
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
Human Verification
Keith Black 125 flat top pistons tuneport Engine 1 Jun 15th, 04 09:55 PM
Removing domed pistons? Silver69Camaro Performance 18 Jan 14th, 04 02:16 AM
AFRs with dome pistons? 1FASTZ Performance 0 Feb 19th, 03 11:58 AM
Gonna get pistons, but hit obstacle BreathWeapon Tech 2002 5 May 30th, 02 12:07 AM
Info about TRW pistons GM man Engine 8 Apr 7th, 02 12:45 AM
