1991 Camaro Engine Swap (88 IROC engine) - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 16th, 05, 12:56 PM Thread Starter
Sean
Send a message via AIM to Racing_Master Send a message via MSN to Racing_Master
Hey, been a bit, been busy... Anyway I want to ask about engine swapping. I am buying an 88 IROC-Z TPI engine, 350 block, and I am buying trannie, and differential, and maybe engine mounts from the iroc.... if needed. I want to know what I need to transplant it, what other parts (Assuming the engine is full working order, it isnt right now, rebuilding it). I dont want to place the engine in and then have my front end to low, scraping against the ground, or have it not work because i am also changing it from auto to manual. Also i dont want my stopping to suddenly get so horrid I cant stop, also I dont want to have my guages not being calibrated for the engine... any help would be appriciated
cheers
Racing_Master is offline
post #2 of 8 (permalink) Old Oct 17th, 05, 05:01 AM
Jake-68's rule
Re: 1991 Camaro Engine Swap (88 IROC engine)
Since you're going from a V6 to V8, everything you can think of will need to be changed.
ECM, engine wire harness, accessory brackets, radiator, alternator(maybe), coolant hoses, engine mounts. These are just a few I can think of. Is the donor car in your posession? If it is, this will make the conversion much easier.
As far as gauges go, the sending units for them go with the car, not the engine.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
post #3 of 8 (permalink) Old Oct 18th, 05, 09:15 AM Thread Starter
Sean
alright. the donor car is missing a few things (in the scrapyard).. its missing: ECM (has wiring harness still, ECM is missing, probably in the car somewhere, just cant find it, someone took parts off and threw them everywhere in the car), top plate for the throttle body, throttle body bolts, intake bolts, AC bolts, AC belt, Dual electric fan assembly, and intake piping. it has everything else... how much would the ECM cost to get?
post #4 of 8 (permalink) Old Oct 18th, 05, 09:48 AM
Jake-68's rule
Repaired ECM's can be bought aftermarket for under $100, but need a core. Be sure to get and take the piggyback controller made by Bosch on the ECM. You'll need its wire harness as well.
Also, fuel tank pump for your TPI MPI.
post #5 of 8 (permalink) Old Oct 18th, 05, 01:33 PM Thread Starter
Sean
OMG! i just found something! http://cgi.ebay.com/ebaymotors/82-92...spagenameZWDVW Check out the location.. .Belmont NH... I live in Hooksett NH, The car i am scrapping is in hooksett NH... in a junkyard... thats an iroc-Z computer... Thinking its from the same car i am looking at? if it is Ill bid on it
post #6 of 8 (permalink) Old Oct 18th, 05, 01:49 PM
Jake-68's rule
Only if the part/service number of the mentioned controller crosses to the donor car. And what processing chip is inside under the cover?
post #7 of 8 (permalink) Old Oct 19th, 05, 04:02 PM Thread Starter
Sean
It is not from the same car but I heared it will work with the engine. I just want to confirm that it will work with the 350/305 that I am looking at in the IROC
post #8 of 8 (permalink) Old Oct 20th, 05, 04:22 AM
Jake-68's rule
It might, but br cautious.
Human Verification
PU engine 'support' parts (non Camaro) DL Engine 2 Jan 5th, 05 03:23 PM
engine swap... front of engine is highier than rear. Is that bad? JIM68 Engine 5 Jan 19th, 04 07:06 PM
engine swap for camaro zman91 Engine 1 Jan 23rd, 03 05:39 AM
Engine Swap for a 1985 Camaro Brown584 Tech 2000 1 Jul 4th, 00 10:54 AM
What is needed to swap a 4 speed to a turbo 350 in a 69 camaro? wildmoose Engine 3 Feb 4th, 00 09:53 AM
