750 CFM too much for a 350 engine - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 14th, 06, 07:37 PM Thread Starter
I have a Edelbrock 1407 750 CFM ( Weber ) carburetor on a 350 CI engine with a mild cam. Is this the right carb for this engine? If so, what would you recommend? There are two screws on the front of the carb. Can somebody tell me how to adjust? Thanks.
Charles Brown is offline
post #2 of 12 (permalink) Old Jul 14th, 06, 08:23 PM
Re: 750 CFM too much for a 350 engine
750CFM sounds too big for a mild cam. IMHO, 600- 650CFM would be a better choice.
buenymayor is offline
post #3 of 12 (permalink) Old Jul 14th, 06, 08:32 PM
Marc
mnm99's Avatar
I'm running a holley 600 Vac sec on a comp 280H, 10.1:1 350. Runs great!
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #4 of 12 (permalink) Old Jul 14th, 06, 09:51 PM
Moderator .. Jim
click's Avatar
I removed the Holley 750 and edelbrock that was on mine when I bought it and went with Qjet 650 and cast iron manifold.. runs great and MUCH better mileage compared to the Holley, it was way to much.
Photos of my Camaro for viewing
click is offline
post #5 of 12 (permalink) Old Jul 14th, 06, 11:22 PM
Harley D
HarleyD67's Avatar
For a 350 to need a 750cfm carb it needs to be built to the hilt and designed to spin way past 6k. With your set up you would be much happier with a 600 vac. secondary carb. It will give you better throttle response better drivability and better fuel economy. Not to mention easier to tune.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.7281/4-11.83@115.59
firstgens.com
HarleyD67 is offline
post #6 of 12 (permalink) Old Jul 15th, 06, 02:48 AM
Chad
yup as others have said 750 is overkill unless you got some nice flowing heads big cam and high compression
BTW holley has an online questionaire on their site now that will give you an approximate CFM for your engine.
1stgenCR is offline
post #7 of 12 (permalink) Old Jul 15th, 06, 10:48 AM Thread Starter
I think I will drop down to the Edlebrock 600. My 750 is mounted on a high intake plate. What is the advantage to this vs mounting it straight to the intake itself?
post #8 of 12 (permalink) Old Jul 15th, 06, 10:52 AM
Guess
HwyStarJoe's Avatar
So, for decades, all the engines built by GM with Q-jets on them were all way over-carbed?
HwyStarJoe is offline
post #9 of 12 (permalink) Old Jul 15th, 06, 01:32 PM
Walter
The quadrajet has the tiny primaries, but the secondary top flap is opened via vacuum, so depening on the tuning whether or not they opened all the way or not.
wildman926 is offline
post #10 of 12 (permalink) Old Jul 15th, 06, 02:17 PM
G.M. had it right with those small primaries. I tried a 750 on my 327, way to big. Even the 600 I use now still has too large of primaries for my liking. I'd switch back to a Quuadrajet, but I'd have to get a new intake also, or use an adapter. Fuel Injection ? Maybe.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #11 of 12 (permalink) Old Jul 15th, 06, 02:27 PM
Use an adapter, they work just fine.
onovakind67 is offline
post #12 of 12 (permalink) Old Jul 15th, 06, 02:41 PM
If the 750 was a vs carb it should be fine... but a smaller carb would increase throttle responce.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
RedЯum <-Pics
More here
Human Verification
I Need Pictures of A/C compressor mounted. 350 engine POCKER Heating & Cooling 5 May 31st, 06 05:22 AM
I Need Pictures of A/C compressor mounted. 350 engine POCKER Heating & Cooling 2 May 27th, 06 08:32 AM
67 RS/SS 350 Need help with Engine Compartment cjmace Engine 1 Jan 31st, 06 04:24 AM
Engine swap 305tbi to 350 carb hilliusracing31 Engine 1 Jan 28th, 06 02:20 PM
Timing of 350 engine GreyShadows Performance 12 Apr 19th, 04 12:24 PM
