383 stroker timing help - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 21st, 06, 10:57 PM Thread Starter
i cant seem to get the timing right what should be the best timing for this block? it was set at 8* retard and it doesnt ping but when you set it to 8*advance it pings? its at 1* advance and still pings? the more retard the timing the better? im so confused
specs
Hydraulic Camshaft
.050 Duration: 234 Intake; 244 Exhaust
Advertised Duration: 300 Intake; 310 Exhaust
Cam Lift: .325 Intake; .340 Exhaust
Valve Lift: .488 Intake; .510 Exhaust
Lobe Center: 107 Intake; 117 Exhaust
Forged steel crankshaft
10.3:1 compression ratio
High performance rod bolts and nuts
High rev lifters and performance valve
springs with retainers
High volume oil pump
Double roller timing set
Flat top hypereutectic pistons and moly rings
Harmonic balancer
Screw in rocker studs
High performance stainless steel valves:
2.02 Intake; 1.6 Exhaust
High performance camshaft
High performance bearings
High performance head gaskets
Four bolt main block
Dart Iron Eagle heads
Full roller rockers
With Flex Plate
750 edelbrock carb and rpm intake
hei msd built in coil
383 stroker, suede interior
jigga99 is offline
post #2 of 9 (permalink) Old Aug 22nd, 06, 02:51 AM
Re: 383 stroker timing help
I think you either have the wrong timing tab/balancer combo, or else a slipped outer ring on the balancer. The thing shouldn't even start at 8* retarded. What cc's are the heads? Gasket thickness? Deck height? 2 or 4 valve reliefs? You could have more compression than you think. Did you verify TDC between the balancer and timing tab when you assembled the engine?
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #3 of 9 (permalink) Old Aug 22nd, 06, 11:22 AM Thread Starter
how do i check top dead center? or cheack and see if the markers are in the right spot?
jigga99 is offline
post #4 of 9 (permalink) Old Aug 22nd, 06, 12:16 PM
DjD
DjD's Avatar
There are other ways but this will work... Pull the plugs and put your thumb over the plug hole on the #1 cyl. It's the closest to the radiator on the drivers side of the car. Pull the coil wire and with your thumb over the plug hole bump the engine around until pressure builds up and blows past your thumb. If your mark is right and you have the right pointer you should find the mark just approaching the pointer.
If that is what you have then you can put a socket on the crank and turn the engine by hand and line the timing mark with the pointer. If the pointer and mark are not even close, then you'll need a piston stop to aid you in dialing in TDC from here but you should be real close at this point...
...Dennis
DjD is offline
post #5 of 9 (permalink) Old Aug 22nd, 06, 12:50 PM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Dennis, just for my information how does the piston stop work.
-Doug
68 RS/SS Conv
Restoration started 5/2007.
Have it for 08 nope
Have it for 09? nope but it runs and moves
Have it for Spring 2010?
thedugan is offline
post #6 of 9 (permalink) Old Aug 22nd, 06, 01:14 PM
DjD
DjD's Avatar
In a nut shell you screw the positive stop (piston stop ) into the plug hole and turn the engine over by hand until it stops (piston hits the positive stop) and you mark the spot on the dampener. Then you turn the engine over by hand the opposite direction until the piston hits the stop again now mark the dampener again. TDC is directly in the middle of the 2 marks.
If you were degreeing a cam you would use a degree wheel instead of marking the dampener for more accuracy...
...Dennis
DjD is offline
post #7 of 9 (permalink) Old Aug 22nd, 06, 02:43 PM
JohnZ's Avatar
Here's what a piston stop tool looks like; you definitely have a timing tab issue.
JohnZ
CRG
'69 Z/28 Fathom Green
JohnZ is offline
post #8 of 9 (permalink) Old Aug 22nd, 06, 03:35 PM
Doug
thedugan's Avatar
So do you have to set the piston stop? It looks like you can spin it.
-Doug
68 RS/SS Conv
Have it for 08 nope
thedugan is offline
post #9 of 9 (permalink) Old Aug 22nd, 06, 03:53 PM
DjD
DjD's Avatar
Yes, you can adjust it in or out to narrow the range on either side of TDC. There are also piston stops that have a hole iin the center to allow the compression out as you near TDC.
...Dennis
DjD is offline
Human Verification
383 stroker 73 stroker Engine 18 Aug 7th, 09 01:01 PM
How many people with a 383 stroker? milehigh67 Bench Racing 30 Aug 27th, 06 05:53 PM
396 vs 383 stroker jdbr1 Engine 14 Dec 29th, 05 11:08 PM
383 timing with 6" rods nitrous383 Engine 4 Apr 24th, 04 02:07 PM
