P1441 - Manufacutrer Control. Auxiliary Emission Controls - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 28th, 06, 01:33 PM Thread Starter
Hey guys,
I've been getting a SES code for a while. I would clear it and it would stay off for a few weeks then come back on. My OBDII tester reads "P1441 - Manufacturer Control. Auxiliary Emission Controls". Just wondering if anyone has an idea of what it might be. Thanks guys!
BTW I have a 1997 Camaro RS 3.8...103k miles.
blt65 is offline
post #2 of 7 (permalink) Old Sep 28th, 06, 02:24 PM
Banned
Re: P1441 - Manufacutrer Control. Auxiliary Emission Controls
Go to a smog station and ask them to decode it b/c they should have ALL codes!!
I would decode it for you, but I think our I/M Unit Chief at work sent his big decode book to the St. Louis office??
If Haskins doesn't have the big book, I will e-mail Chuck to try to find out...
Will get back.....
pdq67
post #3 of 7 (permalink) Old Sep 28th, 06, 02:27 PM
Vintage 68's Avatar
P1141 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 7 (permalink) Old Sep 28th, 06, 03:55 PM
Banned
Will that get you OK??
pdq67
post #5 of 7 (permalink) Old Sep 28th, 06, 06:01 PM
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 7 (permalink) Old Sep 28th, 06, 07:42 PM
george
disconnect the purge solenoid connector and attach a vacuum pump to the evap side.Increase idle speed to 1500 rpm.If you register vacuum,replace the purge solenoid.If the solenoid passes,then you will need a scan tool to monitor evap parameters to accuratly diagnose p1441.
fatblock is offline
post #7 of 7 (permalink) Old Sep 28th, 06, 09:18 PM
Vintage 68's Avatar
Red face Re: P1441 - Manufacutrer Control. Auxiliary Emission Controls
Okay, so Mark can read primary numbers and I can't ...
Actually I just had that code P1441 on a family car - it was a bad solenoid.
Sorry for the mis-lead on the 1141 code
1968 Convertible
Some trucks
Human Verification
