Would a 396 block be much stronger than a 427/454? - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 6th, 06, 05:59 PM Thread Starter
I have an abundance of std bore 396 engines and a strong desire to experiment with a twin-turbo setup.
By the time I'm done, certainly the cost of the block would be inconsequential anyway, but out of curiosity, I'm wondering if the thicker walls of a 396 would be stronger than a 427 by any noticeable margin?
I was thinking a 4340 crank and rods, splayed billet caps, and blok-cement the bottom couple of inches. Or after machining and parts would I be at the cost of a fully-forged crate block in 454/502 size anyway?
Thanks,
1969 RS/SS 396 Camaro [MPFI Supercharged 502 Under Construction]
2007 427 Z06 Corvette
1969 Pontiac 2+2 427/390
2003 CL600 BiTurbo Renntech Stage III (635hp - 11.7@118) [Sold!]
2006 Range Rover Eaton Supercharged
davepl is offline
post #2 of 11 (permalink) Old Nov 6th, 06, 06:23 PM
Re: Would a 396 block be much stronger than a 427/454?
I guess it depends on which casting #'s 396 you're talking about, I've heard some are thicker than others, in fact, I've heard of them being bored out .125 to 427 cubes with no issues. My gut instinct would be to measure the cylinder wall thickness so you know for sure, decide if an overbore is needed, and then make your decision from there. If you've got an abundance of them, I say go for it!
kz1000ltd is offline
post #3 of 11 (permalink) Old Nov 6th, 06, 06:28 PM Thread Starter
Any way to check wall thickness without a sonic thingy?
davepl is offline
post #4 of 11 (permalink) Old Nov 6th, 06, 06:33 PM
Not a lot of difference between them. Both 2 bolts are close and so are the 4 bolts except the 65 396 4 bolt block is supposed to be thicker but I have never checked one. I would go with an aftermarket block.
oger is offline
post #5 of 11 (permalink) Old Nov 6th, 06, 06:48 PM
Gary
Knock out the core plugs on one side of the engine. Check the distance between the cylinder barrels. If it's 1/2" or so, they're thinner walls, don't generally bore more than .060 over. if they're more like 1/4", so a pencil just fits between 'em, they have much thicker cylinder walls and can be bored to about the same dimension as a regular 427/454 block. I'd try to find a -289 block and use the bigger bore block - those are supposed to be some of the thickest cast.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
Busted Knuckles is offline
post #6 of 11 (permalink) Old Nov 6th, 06, 06:51 PM Thread Starter
The two blocks I have handy are 3969854 and 3955272. Where would the -289 you refer to appear?
Thanks,
davepl is offline
post #7 of 11 (permalink) Old Nov 7th, 06, 04:16 AM
Bob
289 would be the last 3 numbers in the sequence.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
phel69 is offline
post #8 of 11 (permalink) Old Nov 7th, 06, 04:30 AM
Gary
Bob is right, full casting number is 3999289. I've looked at a lot of 396's but never took the time to check casting numbers on the thicker blocks. That would be a good group of numbers to have handy, though!
Gary Adrian
FCS Harmony Racing
post #9 of 11 (permalink) Old Nov 7th, 06, 05:34 AM
Banned
Smile Re: Would a 396 block be much stronger than a 427/454?
Ed Saffel say's that he's found that a '66 396, -961 block would bore out .155" to 4.250" to create a 454 with no lower crank area grinding.
pdq67
post #10 of 11 (permalink) Old Nov 7th, 06, 04:28 PM
I have a 66 961 block that a pencil will go between the cylinders. I don't know what he has but I haven't come across one.
oger is offline
post #11 of 11 (permalink) Old Nov 7th, 06, 05:35 PM
Banned
Oger,
There you go!
Just about like cc'ing head chambers to me..
pdq67
Human Verification
Rs 396 Big Block indpthwill Engine 2 Feb 27th, 06 12:43 PM
Getting the most out of my 325 HP 396 Big Block tronic72 Performance 4 Jul 28th, 05 12:17 PM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 02:08 PM
396 & The Big Block Appeal ssdanny69 Tech 2000 16 Dec 21st, 00 08:28 AM
67 Camaro 396 Block Question!?!?!?!?!?! 69z28rsMATCH#s Tech 2000 7 Nov 14th, 00 02:22 PM
