Flywheel Heavy VS Light - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 31st, 06, 09:16 PM Thread Starter
I have a 67 camaro with a SB 350 4 speed 373 gears about 350-375hp. I have 2 flywheels one weighs 33lbs the other 18lbs. Both steel not sure what difference it makes need help choosing. No racing street only.
Britter is offline
post #2 of 5 (permalink) Old Dec 31st, 06, 09:31 PM
Re: Flywheel Heavy VS Light
The lighter wheel will allow the motor to rev quicker, but it requires slipping the clutch more to get the car moving on the street, the heavier wheel will provide better street manners having power to spare to get the car rolling but it will make the motor less responsive to the throttle.
Larger Dave
Larger Dave is online now
post #3 of 5 (permalink) Old Jan 1st, 07, 07:42 AM
I dont know of anyone that would want to slip a clutch under any full throttle application on a street car. A heavier wheel is good for a heavier car. The matching of components suchs as low gear ratio in your trans and at the diffrerential will make a huge difference in your performance! I am sure with the lite wheel you have sufficent power to spin your rear tires with ease. Anyone has to agree that slipping a clutch on a regular basis you will be replacing pressure plates and discs all the time. To get a good grip on your question I would call the people at McCloud on their tech help line. 714-630-3668. This company has been in business a very long time and reputable with the right parts and answers for all of your needs!
FRANK ESKRA is offline
post #4 of 5 (permalink) Old Jan 4th, 07, 07:31 AM
Jeff
I tried both a lightweight and a standard weight in my car and really preferred the feel of the heavier one. unfortunately I had tried that one first so i had to do the swap twice!
Jeff Supinski
'69 SS - Hugger orange, white stripes, Ivory interior. ZZ4,M-20,3.42's
'07 GMC Sierra Crew Cab
'79 L-48 Corvette
'06 Goldwing
camaro-69ss is offline
post #5 of 5 (permalink) Old Jan 4th, 07, 08:50 AM
Wes
Drag racers go with the heavy flywheel,..more stored energy for blast-off. Road racers lean toward the lighter wheel,..revs quicker out of turns. Most street guys go heavy,..as Larger says, better street manners and you don't have to rev the engine as high to pull away from a stop sign,..which means you don't have to ride the clutch as long.
Do a search,..a few had the lighter flywheel and switched back,.and a few like it.
Straight-line-69 is offline
Human Verification
Interior Light LED Project - Super LED! Brian Lewis Electrical & Wiring 9 Jun 27th, 07 07:38 PM
Temp Idiot Light Test???? 327!275hp!Convt! Electrical & Wiring 1 Jul 13th, 06 08:19 PM
Hazard and Turn Signal Light Issue 68camrs Electrical & Wiring 2 Jan 5th, 06 12:47 PM
Rear light not acting properly....... 2zMax Troubleshooting 4 Aug 13th, 02 09:06 PM
Oil light on, Shoot....now what? Blk69 Troubleshooting 13 Aug 19th, 01 03:15 AM
