69 Console Oil Pressure Line - - PICS??? - Page 2 - Team Camaro Tech
post #16 of 23 (permalink) Old Jun 1st, 09, 07:19 AM Thread Starter
Re: 69 Console Oil Pressure Line - - PICS???
Thanks for the info. Have you experienced any leaks with this kit?
tdb11 is offline
post #17 of 23 (permalink) Old Jun 1st, 09, 10:15 AM
Marc
In my experience, copper leaked. The nylon tube never did.
SS69Cam is offline
post #18 of 23 (permalink) Old Jun 1st, 09, 03:38 PM
Fred
The factory used a alloy line from the area of exhaust heat. Then the line connects to the plastic pipe for the trip to the firewall. Here's the fireproof original pipe on my BBC.
The complete pipe is at the top, the block outlet is in front of the pipe.
Oh, the alloy pipe looks to be made of monel or something similar. Very strong and hard to bend. Not copper.
128.79mph 1.428 60'
Fred Ficarra is offline
post #19 of 23 (permalink) Old Jun 2nd, 09, 06:33 AM Thread Starter
Thanks Fred....you bring up a point that I did not consider. The difference between line routing for a BB vs. SB. Mine is a SB 302 coming out of the rear top of the block just in front of the intake manifold.
Do folks think the "heat" that melted the plastic line could have been related to a connection as you show as it is closer to the exhaust manifold....makes perfect sense.
It seems that, from what I've read the nylon hose was problematic on the SB as I've described as well. Certainly the nylon hose near the exhaust would be really problematic...?
Again, any thoughts on copper alternative kits and what to do to stop / minimize leaking potential??
Thanks, again!
tdb11 is offline
post #20 of 23 (permalink) Old Jun 20th, 09, 12:24 PM
jobu is offline
post #21 of 23 (permalink) Old Jun 20th, 09, 12:25 PM
Originally Posted by mark x22 View Post
this is the correct ends for the original gauges .
I bought this oil pressure line from Paragon Reproductions (Thanks Mark!), worked great. This line has the correct cone-shaped ferrule w/ a little pin insert at the end. My previous leaking problems were from using the over-the-counter lines w/ the barrel-shaped ferrules--they did not match up well enough to my original gauges and i could never get a good enough seal to stop the leak!
jobu is offline
post #22 of 23 (permalink) Old Jan 30th, 10, 08:45 PM
Tory
Camaros-n-Chevelles's Avatar
What size hole is correct for the routing of the Oil Line?
Tory
1968 Camaro Coupe
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396
1968 Malibu L-79, 1 of 4082 ~ SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds with Factory Sunroof, 1 of 99 ~ SOLD
1992 Camaro 396 LS, 4L60, 9" Posi w /3.50:1 Gear Set
Camaros-n-Chevelles is offline
post #23 of 23 (permalink) Old Apr 28th, 10, 02:56 PM
BARTELL
So what is the verdict? Hard line off engine, then convert to nylon to guage? Nylon ok for SB? All hard line needed for SB?
BTELL67 is offline
Human Verification
