68 Positive Battery Cable Route - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 26th, 09, 11:58 AM Thread Starter
Lane
There are two positive battery cable clips holding the cable to the cross members.
My question is, the 2nd clip on the lower cross member, does it go on the left or right side of the access hole in the cross member? (The access hole I speak of is about 2" in diameter. There is one on the passenger side and one on the drivers side.)
I have a small hole on the left AND right side of this 2" hole. I BELIEVE it goes on the RIGHT side of this hole BUT I have a picture of a 69' that shows this clip on the LEFT of the 2" hole. I have a 68' 350.
The AIM guide does not spell this out.
Thanks,
Lane
Lane 68 is offline
post #2 of 16 (permalink) Old Dec 26th, 09, 01:17 PM
Re: 68 Positive Battery Cable Route
Are you looking at UPC12-A4?
Do you no longer have the hole/s for the clip/s drilled into the subframe? They are drilled into all subframes regardless of application. ie: 6 or 8 cyl, so I would assume that someone has filled them in if they are no longer there. Maybe get a screwdriver and press it against the frame incase it's just body filler blocking them up.
This is a pic of a 1968 subframe from a V8 Camaro that I was doing a repair on. It features the correct 1968 bump stops to confirm it's year. (However, it doesn't matter because all 67-69s have the cable clips in the same location.)
You can still see the factory clip on the front side of the main crossmember, and the hole for the other clip on the top side of the front/smaller crossmember.
The clip you are referring to is almost exactly vertically inline with the upper engine frame mount bolt holes. In other words, to answer your question, the clip is on the vehicle's right side of the control arm access hole. The left would drop the cable way too far under the pan rail.
Pretty sure the hole diameters are 1/4".
BlackoutSteve is offline
post #3 of 16 (permalink) Old Dec 26th, 09, 06:09 PM Thread Starter
Lane
Steve,
THANKS for your information. Looking at your pic, the cross member access hole has the same two 1/4" holes on each side of it that I refer to, on the passenger side, one on each side of the hole. I was not sure WHICH 1/4" hole to place the clip. I will use the hole on the "vehicles" right side of the access hole. A picture tells a thousand words!!
THANKS A LOT for your help, the AIM is a poor example.
Lane
Lane 68 is offline
post #4 of 16 (permalink) Old Dec 26th, 09, 07:22 PM
You're right.. I forgot about the other hole.. Has it been tapped for a 5/16unc? Can't remember.. The clip holes are not tapped.
Here's a better shot of a dead subframe that I used as a donor to repair others. It shows all three holes clearly. It's the top one of the two on the main crossmember that you're interested in.
post #5 of 16 (permalink) Old Dec 27th, 09, 05:20 PM Thread Starter
Lane
Steve,
Thanks again for your help and pics. I appreciate your effort.
If you have any more engine bay pics showing a stock 350 w/ AC send them.... IF you have time.
I have a 68 RS/SS 350, A/C,PS,PB,AM radio,Houndstooth interior, Black vinyl top,tripoli turquoise paint. In restoration mode.
Thanks again
Lane
Lane 68 is offline
post #6 of 16 (permalink) Old Dec 27th, 09, 05:49 PM
Roger
I don't know if the 67s are like the 68s but this is a picture of my clip.
Roger
rogerh is online now
post #7 of 16 (permalink) Old Dec 27th, 09, 06:43 PM
Roger
Yes, the 1st 3 years are all the same and I dare say Firebirds, Novas, Omegas, Venturas, and Apollos that shared these subframes are too.
post #8 of 16 (permalink) Old Dec 29th, 09, 08:23 PM Thread Starter
Lane
Roger,
Thank You for your great picture. I appreciate your help.
I am in the garage this weekend !!
Lane
Lane 68 is offline
post #9 of 16 (permalink) Old Jun 28th, 10, 05:18 PM
Kevin
Old post but need info on putting new clips on.......
How do I get new clips on ..there must be a trick...any help??
69Rook is offline
post #10 of 16 (permalink) Old Jun 28th, 10, 07:32 PM
Roger
Check out this thread.
Roger
69 Positive cable clips????
post #11 of 16 (permalink) Old Jun 29th, 10, 12:45 AM
Kevin
Thanks roger..not sure if i completely understand but i will go with the rivet gun ..trial and error..too bad these clips are about 14 bucks each
69Rook is offline
post #12 of 16 (permalink) Old Jul 1st, 10, 01:36 AM
I used a dynabolt to flare mine. Worked a treat.
post #13 of 16 (permalink) Old Jul 2nd, 10, 08:43 AM
Kevin
Steve,forgive my ignorance but what is a dynabolt?
69Rook is offline
post #14 of 16 (permalink) Old Jul 2nd, 10, 12:48 PM
A concrete anchor bolt..
Take the sleeve off and use a spacer or perhaps over-sized nuts to shim the distance between the clip and nut. The flare on the Dynabolt's shank will expand the clip's rivet into the subframe.
I think I used a M4 or maybe M6 sized Dynabolt
post #15 of 16 (permalink) Old Jul 5th, 10, 09:01 PM
Kevin
got it, i'll give it a try and let ya know how it goes. thanks
69Rook is offline
Human Verification
