Gas Gauge Failure. . .How to fix...Thank you, Brian (69 Pace) - Page 5 - Team Camaro Tech
post #61 of 103 (permalink) Old Aug 1st, 13, 10:08 AM
69-Pace's Avatar
Re: Gas Gauge Failure. . .How to fix...Thank you, Brian (69 Pace)
Hey no problem - hope the guys at work find it is in working order with a set point lower then 56 Ohms
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #62 of 103 (permalink) Old Aug 2nd, 13, 03:54 PM
Re-Pete
Well crud...still need the 100 Ohm pot to test the module (at the office) and Radio Shack does not carry one. Or is it a 100K ohm?
1968 Camaro RS/SS 350 - owned for 21 years
MMMM_ERT is offline
post #63 of 103 (permalink) Old Aug 2nd, 13, 07:00 PM
Jake-68's rule
0-100 ohms would be ideal, but 0-1K has better availability.
Give a man a rescued dog for the health of both their souls.
'With age comes wisdom, but then wisdom ages you even more.'
CUBS - 2016 World Series Champions
post #64 of 103 (permalink) Old Aug 2nd, 13, 07:36 PM
Re-Pete
I'll keep that in mind when I hit Frys. Frys claims they have this in stock.
http://www.frys.com/product/2915755
DO you have a procedure for testing the module? I'm going to be doing this out of the car. What to hook up where?
Thanks!
MMMM_ERT is offline
post #65 of 103 (permalink) Old Aug 2nd, 13, 08:14 PM
69-Pace's Avatar
Radio Shack was out? Mine always has a bin full of them and they are cheaper too
69-Pace is offline
post #66 of 103 (permalink) Old Aug 2nd, 13, 09:30 PM
Re-Pete
Not just out...they don't even list them on their website.
MMMM_ERT is offline
post #67 of 103 (permalink) Old Aug 3rd, 13, 08:19 AM
69-Pace's Avatar
Sure they do. Here are the two that will work for what you are testing:
One is a Linear-Taper which means when in the mid way position resistance in Ohm's is equal on both lugs of the device. An Audio-Taper that is not quite true. I tend to think of it in stereo terms. One is the balance control (linear) and one is the volume control (Audio). Since we are only using one lug of the potentiometer either will work.
You jump the center lug to either of the side lugs, then use the two side lugs as the in and outs. You can just alligator clips or for a permanent toolbox diagnostic tool, solder the leads, and or mount it in a kit box with a knob and a face plate marking various resistance value milestones. Here are your Radioshack part numbers.
Option one:
Part number 271-1714 is an Linear-Taper
http://www.radioshack.com/product/in...ductId=2102789
This one should be in the pull out bin or can be ordered on-line and in store. Preference is for this Linear unit as opposed to the Audio pot listed below.
Option two:
Part Number 271-1722 This is an Audio-Taper
http://www.radioshack.com/product/in...ductId=2062358
This one is always located in the pull out bins unless you are in a large store in a heavy nerd community patronized like big nerds like me where it might actually have a peg hook on the wall.
69-Pace is offline
post #68 of 103 (permalink) Old Aug 3rd, 13, 08:44 AM
69-Pace's Avatar
And I forgot to include the link to JohnZ excellent description on testing using a potentiometer on Corvette C1 fuel senders in PDF format. A worthwhile save even though it is written for the Vette audience - the process is the same for all GM fuel senders of that period. Just think 0-90 when he is talking about 0-30 Ohm's for empty to full, 45 when it says 15 is half tank and its all the same.
http://www.lbfun.com/warehouse/tech_...lGaugeTech.pdf
Name:	diagnostic tool potentiometer.jpg
69-Pace is offline
post #69 of 103 (permalink) Old Aug 3rd, 13, 11:16 AM
Re-Pete
Okay... I thought you said it had to be 100 Ohm.
These two are 5K Ohm and 100K ohm. Pardon my ignorance of electronics...but doesn't that that translate to 5000 Ohm and 100000 Ohm?
...and yeah...our Radio Shacks are mostly cell phones and accessories now. It's terrible.
Option one:
Option two:
MMMM_ERT is offline
post #70 of 103 (permalink) Old Aug 3rd, 13, 08:18 PM
Alan
Basic question. I scooted under the tank and can't see a ground coming off the top of the tank on the passenger side anywhere!!! Anyone got a photo or is it in the assembly manual?
alan
alanrw is offline
post #71 of 103 (permalink) Old Aug 3rd, 13, 08:20 PM
69-Pace's Avatar
Yes they are, but as long as they go to at least 100 Ohms you are okay.
Hard to find them 0 to just 100 Ohm's these days on the shelf. And if you have a higher top end you can use it for all three bastard children, the Water Temp gauge, Fuel Gauge and Tachometer.
69-Pace is offline
post #72 of 103 (permalink) Old Aug 3rd, 13, 08:27 PM
Alan
100 ohm potentiometer
http://www.allelectronics.com/make-a...M-SHAFT/1.html
alanrw is offline
post #73 of 103 (permalink) Old Aug 3rd, 13, 08:28 PM
69-Pace's Avatar
alan
Yes it is in the AIM but like so much of it, not so clear. The screw is tiny and it is on the pass side of the pass side hanger nodule and hard to see because of the muffler.
Here is a picture during my recent prep for a new tank.
Name:	Trunk Pan prep 005.jpg
69-Pace is offline
post #74 of 103 (permalink) Old Aug 3rd, 13, 08:30 PM
Alan
And that is the passenger side forward mount correct?
alan
alanrw is offline
post #75 of 103 (permalink) Old Aug 3rd, 13, 08:32 PM
69-Pace's Avatar
And only a Dollar too! Thank's Alan.
69-Pace is offline
Human Verification
