Where to get terminal ends? '69 Camaro - Page 2 - Team Camaro Tech
post #16 of 24 (permalink) Old May 15th, 12, 03:09 PM
69-Pace's Avatar
Re: Where to get terminal ends? '69 Camaro
Try calling lectric limited and American Auto Wire
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #17 of 24 (permalink) Old May 15th, 12, 03:15 PM
Matt
I called American Auto Wire and they said they didn't have anything. The guy I talked to recommended looking at pcsconnectors.com. I went to the website and found these. www.pcsconnectors.com/delphi_terminals.aspx
They look similar but don't know if they are the same.
Never heard of lectric limited. I will have to see if I can find them and give them a call.
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
MW67RS is offline
post #18 of 24 (permalink) Old May 15th, 12, 03:35 PM
Matt
Just doing some more looking online and found this site. Shows a picture about 1/2 way down that looks like my connector. http://www.rowand.net/shop/Tech/Auto...Connectors.htm
I think I will give them and try and find out. It appears that the 67 is different than the 68 and 69.
Matt
MW67RS is offline
post #19 of 24 (permalink) Old May 15th, 12, 03:52 PM
cb
Send a message via Yahoo to flyingskibiker
I have PCS bookmarked from other threads. Here is one of my links:
http://www.pcsconnectors.com/search.aspx?find=twin+lock
Though, I'm pretty sure I had it marked because those terminals are used in things like the turn signal switch, rear body harness, and center console... They look the same as what you've pictured. But...
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #20 of 24 (permalink) Old May 15th, 12, 04:10 PM
Vintage 68's Avatar
Thumbs up Re: Where to get terminal ends? '69 Camaro
Those bulkhead connectors are the "TwinLock" design from Packard Industries ...
There was a thread eons ago that identified them and gave a source, but they've gone out-of-bus. or at least off-the-web according to a recent search - they sold them in bags of 10~12 for @$8
There are two common sizes in the connectors;
12/14 Ga = PCS #6288953
18/20 Ga = PCS #2973915
There's also a special Crimping Tool for them - it was expensive
1968 Convertible
Some trucks
Vintage 68 is offline
post #21 of 24 (permalink) Old May 15th, 12, 04:42 PM
Matt
Is the crimper necessary or can you use needlenose pliers and solder?
Matt
MW67RS is offline
post #22 of 24 (permalink) Old May 16th, 12, 10:42 AM
Vintage 68's Avatar
Wink Re: Where to get terminal ends? '69 Camaro
I guess you 'could' ...
Heck I've seen a guy closing a crimp with a vise
But using the correct tool will give the best mechanical bond and assure the strain-relief is correctly locked on the insulation.
I have seen these crimpers in stores for under $20 (I know, a lot to spend for something you don't think you'll use often) - I bought mine years ago at a "Bargain" price of just under $100 ... and I've seen them for twice that on some sites ...
Crimps look like this - Click image for larger version
Name:	Crimp Tool with Packard connectors.jpg
I use mine more often that I would even thought, specially because they will do most of the GM and others Packard style connectors.
Maybe you can just check around with a few shops in your area a find a mechanic that would be willing to do the crimps for you after you've got everything ready for a few $$ - worth a try anyway.
1968 Convertible
Some trucks
post #23 of 24 (permalink) Old May 16th, 12, 11:16 AM
Matt
I can't spend $100 for crimpers but could swing $20. Any idea where I could find a set of crimpers for close to $20?
Matt
MW67RS is offline
post #24 of 24 (permalink) Old May 16th, 12, 11:23 AM
Vintage 68's Avatar
Well ... not the place I bought mine through, or this place - http://crimpsupply.com/packard-delph...FWIGRQod5msQlw -
But 'Amazon' seems to have several - like this http://www.amazon.com/Delphi-Packard-Five-cavity-Wide-range-Crimping/dp/B003MWJ6SA - that may be just the ticket for the $$
1968 Convertible
Some trucks
Human Verification
