67 RS Help - new AAW wiring now doors don't open - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 31st, 12, 12:56 AM Thread Starter
1967 SS/RS 350 with AT, console gauges
I re-wired my entire car from front to back with American Autowire Factory Fit wiring. I also replaced the RS relays (four seasons), RS limit switches (AAW), RS circuit breaker (AAW), and voltage regulator (Wells VR715). All new fuses and light bulbs as well.
I have a few problems, but the RS system is the first item I was going to try and fix.
When the headlight switch is pulled, the lights light up, but the doors do not open. If I open the doors manually, the doors shut when pulling the switch out.
I went through the www.retro-electro.net site and limit switches and relays seems to be connected correctly. I even double checked the headlight switch wiring and looks to be correct.
cam1967rsss is offline
post #2 of 8 (permalink) Old Oct 31st, 12, 02:55 AM
Brent
67Rally's Avatar
Re: 67 RS Help - new AAW wiring now doors don't open
Did you reverse the polarity of the wiring to the headlight doors by accident?
67Rally is online now
post #3 of 8 (permalink) Old Oct 31st, 12, 03:07 AM
Jake-68's rule
As Brent suggests, either the DC motor is wired backwards, or open/close relays are wired backwards, or headlamp switch is wired opposite.
Give a man a rescued dog for the health of both their souls.
'With age comes wisdom, but then wisdom ages you even more.' GO CUBS! Other Stuff
post #4 of 8 (permalink) Old Oct 31st, 12, 04:33 AM
Jason
blue89bird's Avatar
Did you install the diode harness?
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #5 of 8 (permalink) Old Nov 7th, 12, 12:00 PM
Craig
Had the same issue with mine. Found out that I needed ground jumpers on the the limit switches. This was a whole wiring harness from painless wiring that I had. It didnt have the limit switch grounds included and I had no idea that they were needed. Hope that helps.
67' RS/SS Clone Madeira Maroon ZZ383, 700r4, ford 9 inch 3.73 gears
My build thread
http://www.camaros.net/forums/133-build-projects/211181-madeira-67-a.html
Scruggs67 is offline
post #6 of 8 (permalink) Old Nov 7th, 12, 02:40 PM Thread Starter
Thanks for all the responses guys.
If I did, I didn’t even know I did. How do I check to see if I reversed the polarity to the motors?
I checked my limit switch wiring and relay board wiring against retro electrics website and everything seems to be matching. I will double check again…
Yes, the diode harness is installed. I provided a picture of the ignition switch wiring in hopes that someone can confirm everything is wired right???
pink-IGN
red-BATT
purple-SOL
brown-ACC
There IS only one way to install the ignition connector on the switch right?
Also, here is a picture of my light switch. This is wired correctly right?
My limit switches came with the ground wires and all are attached.
Thanks!
post #7 of 8 (permalink) Old Nov 7th, 12, 04:07 PM
Jake-68's rule
The open and close limit switches may be swapped of physical position, or the motors wired backwards within the motor connector or at the relay socket.
post #8 of 8 (permalink) Old Nov 7th, 12, 04:21 PM
jared
Cam67rsss , Send me a email at jcfcamaro@embarqmail.com and I'll send you some really good info back. Just put 67 camaro in the subject box !!
jcfcamaro is offline
Human Verification
