1967 Camaro wires cut horn relay - Team Camaro Tech
post #1 of 16 (permalink) Old Dec 28th, 12, 07:21 AM Thread Starter
Rick
I searched through the horn relay problems and couldn't find my problem, While repairing the hideaways three wires were tucked up under the the fender with the relays. blue, white and large red. it looks like they would have attached to the rad support above the horn relay where guess what there is a blue, white and large red wire. The large red wire goes into a "resister" and comes out orange. I saw the picture of the horn relay and the wires that go into mine appear correct but in the shot there is a blue and white in the background. Upon further investigation I have now found a brown wire that was cut under the newer tape you can see in the pic. It is now attached to a red wire running under the rad support to the passenger headlight which was dim after hooking up the hideaways. I am attaching a couple pics for help.[ATTACH][ATTACH]Attachment 31495[/ATTACH][/ATTACH]
Ric67 is offline
post #2 of 16 (permalink) Old Dec 28th, 12, 07:45 AM
Jason
blue89bird's Avatar
Re: 1967 Camaro wires cut horn relay
you should really get a new headlight harness, they're fairly inexpensive and you're not going to need to worry about the car catching fire.
Let me check my materials and see if I can figure it out for you.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #3 of 16 (permalink) Old Dec 28th, 12, 07:55 AM Thread Starter
Rick
I assume in past attempts to repair the hideaways there has been some creative wiring. All I can see is the wires around the relay. Everything else appears normal to my untrained eye.
Ric67 is offline
post #4 of 16 (permalink) Old Dec 28th, 12, 09:09 AM
69-Pace's Avatar
Are you still running factory charging and external voltage regulator? If you are these would be the standard front harness wires. Blue brown and red with fusible link.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 16 (permalink) Old Dec 28th, 12, 09:19 AM
I see a horn relay but not a voltage regulator....or is it not in the pic ?
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #6 of 16 (permalink) Old Dec 28th, 12, 09:44 AM Thread Starter
Rick
Its been over 30 years since I have had my hands on a car I could work on, so lets see how my memory serves me.
There is no voltage regulator now, The brown wire (now spliced to red) runs to the alternator. I believe later alternators had the voltage regulator built in ? If I am right then the car has been rewired for this alternator. The wires that were cut and tucked away are of no further use ? I probably have a bad headlight since it was in and out 5 times.
Ric67 is offline
post #7 of 16 (permalink) Old Dec 28th, 12, 10:01 AM
Do you have a wiring schematic? I looked in mine, it is possible that those are the wires that go to the voltage regulator. There should be a blue, white and red wire that goes from the regulator to the alternator. Has someone replaced your alternator with an internal regulated alternator?
'67 SS/RS 350, Muncie M20, Black with black interior.
b17brian is offline
post #8 of 16 (permalink) Old Dec 28th, 12, 10:11 AM Thread Starter
Rick
Yes Brian, that looks like what has happened. I will just tape them up and tuck them away. Mystery solved for today.
Thanks guys I am sure in time you will have me educated !!
Rick
Ric67 is offline
post #9 of 16 (permalink) Old Dec 28th, 12, 10:19 AM
Jason
blue89bird's Avatar
as you found out, it's for your regulator. Going from top to bottom, the wires on the regulator are blue, white, red, brown.
Jason
post #10 of 16 (permalink) Old Dec 28th, 12, 02:11 PM Thread Starter
Rick
Yeah got it. Dim headlight was broken ground wire for the headlight plug.
Thanks guys for the help.
Rick
Ric67 is offline
post #11 of 16 (permalink) Old Dec 28th, 12, 04:01 PM
Jake-68's rule
Do you have a GEN light with ign switch on, engine off?
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas,' '
CUBS - 2016 World Series Champions
post #12 of 16 (permalink) Old Dec 28th, 12, 04:51 PM Thread Starter
Rick
Yes I do have
Ric67 is offline
post #13 of 16 (permalink) Old Dec 28th, 12, 07:41 PM
Jake-68's rule
And it goes out with engine running?
Charging voltage across battery posts is above 13.8 volts?
post #14 of 16 (permalink) Old Dec 29th, 12, 07:08 AM Thread Starter
Rick
Evey thing works as it should. That's why I never noticed anything on the 4 hour drive home when I bought it. It was just when I got into the hideaways that I found the wires. Funny thing though,my son has a friend who is an electrician and he said whoever did the wiring knew what they were doing, everything neat and in the right place.I wasn't there when he looked and never even asked him what he thought. He said no way a backyarder did it.
Ric67 is offline
post #15 of 16 (permalink) Old Dec 29th, 12, 07:43 AM
Rick, your horn relay is upside down. You might think about turning it right side up or the cover could fill up with water.
b17brian is offline
Human Verification
