My under dash wiring harness is in near perfect shape except for the fuse clips in the fuse block. The were pretty corroded and also had some light rust in areas. I sprayed them with De-Oxit electrical contact cleaner. It helped but they still looked rough. I tried to get at them with a little wire wheel on a Dremel tool. You really couldn't get to the inside of the clip that well and now some the plating has stared to come off the outer edges of the some of the clips.
I did put a fuse in each socket and then tested for continuity between the clips. I was good at every socket but I just don't trust them looking like they do.
Can you buy these fuse clips anywhere? Can you buy the fuse block...or just the interior side of the fuse block.....without having to buy the harness itself.
I hate to spend $450 for a new harness when the only thing wrong is a few dollars worth of clips.
Thanks.....Dave
Thanks.....Dave
