removed roof insulation have question - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 24th, 12, 06:16 PM Thread Starter
dondb's Avatar
I see a lot of different materials used to replace the old roof felt. I have dynamat...my question to anyone who used it is: Has anyone had problems with the dynamat coming loose after installation, from the heat? I also scraped it down to bare metal and noticed the surface rust with in minutes. What would be the best coating to put on it before the dynamat. I'm only asking because a lot of the threads i saw were a little older and things may have popped up on better solutions, or problems with a tried solution?
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
2002 Camaro LE SS...Many upgrades
dondb is offline
post #2 of 8 (permalink) Old Apr 25th, 12, 02:58 AM
Re: removed roof insulation have question
Dynamat would be hell to get off if you tried. Heat won't make it come off on its own. People have different opinions but I was very pleased with POR-15 after scraping down to the bare metal. The prep work is a pain, but I think worth the effort. Good luck!
SB 406/700r4/3.55 posi/Hotchkis Stage 2 TVS/Delphi 600 Series PS Box/Holley Terminator EFI
Andrew68 is offline
post #3 of 8 (permalink) Old Apr 25th, 12, 05:35 AM
Send a message via AIM to cuz13
I used a product called master series you can find it online or at the swap meets. Some great stuff, then covered with the dynaliner. Its been 3 years no problems yet.
cuz13 is offline
post #4 of 8 (permalink) Old Apr 25th, 12, 06:34 AM Thread Starter
dondb's Avatar
Did you put any type of sound proofing over the POR-15?
dondb is offline
post #5 of 8 (permalink) Old Apr 25th, 12, 07:27 AM Thread Starter
dondb's Avatar
Just looked up masterseries, looks like a great product, it does state to use a clean air mask, are those hard to find? Did you use their silver product?
dondb is offline
post #6 of 8 (permalink) Old Apr 25th, 12, 10:45 AM
I did, I put down dynamat and then dynaliner on top of that... Very quiet now (well as quiet as you are going to get on a vert!).
Andrew68 is offline
post #7 of 8 (permalink) Old Apr 25th, 12, 11:39 AM
Harry
http://masterseriesct.com/home.html
Beemervet is offline
post #8 of 8 (permalink) Old Apr 25th, 12, 01:25 PM
Yes the silver has metal in it works great. use it on the whole roof frame when i replace skin. No i did not use anything but a regular 3m dust mask and heavy rubber gloves. I definitely recommend the product. They have great customer service I was actually able to speak to the owner.
cuz13 is offline
Human Verification
