Modifying Seat Tracks? - Page 2 - Team Camaro Tech
post #16 of 45 (permalink) Old Jan 10th, 13, 08:30 PM
Garth
Re: Modifying Seat Tracks?
Well, don't know when you bought the covers, but if you read these forums, the headroom issue is no secret. I knew about it (read here)over a year ago, before I made the purchase. That's why I reupholstered one seat at a time for comparison. Must admit, I was quite surprised to see them setting at the same level as shown in the pic. The headroom issue seems to exist with almost any seat you try to plug in there....kinda tight conditions.
Interesting, Don mentions repop springs being heavier duty...
As mentioned, I have about 2" of headroom, but wouldn't mind if there was more. If/when I find another set of tracks cheap, would like to do some experimenting . Also, would be interested in the aftermarket "flat tracks" you mention, if you have a link ?
Garfields Maro is offline
post #17 of 45 (permalink) Old Jan 11th, 13, 05:15 AM Thread Starter
Kip
Here is the link for the aftermarket seat tracks.
http://www.polyperformance.com/rally...3-p-26368.html
kv67ssrs is offline
post #18 of 45 (permalink) Old Jan 11th, 13, 08:15 AM
Andrew Brock
Originally Posted by kv67ssrs View Post
I just want to make it clear that I was very impressed with the quality of the TMI foams/covers, as was my installer. I am in no way bashing the product...
its just this unexpected install issue that has me frustrated.....
Hey TMI, how bout a quick R&D session on shortening the stock stands?? :-)
No offense taken, just wanted to chime in a bit on it.
Lets see, cut, weld, re-install...that about sums up shortening stock stands!
TMIproducts is offline
post #19 of 45 (permalink) Old Jan 11th, 13, 09:24 AM
Fred
77thor's Avatar
... seems like every time I do something to improve my Camaro, I end up having to spend more $$ and change other things just to make it work...
LOL. Ain't that the truth.
Welcome to the club.
77thor is offline
post #20 of 45 (permalink) Old Jan 11th, 13, 01:53 PM
68resto's Avatar
Hey Gang,
Be careful with those aftermarket tracks, I bought a pair and for 1 they are not curved like the factory tracks where the seat metal meets the track. 2nd the factory seats have a lip that cover the track legs about an inch that the stock tracks are not effected cuz of the large legs on the track and the aftermarket track will not slide back and forth cuz of it. 3rd when the track is bolted to the floor pan the release lever will not work because of the carpet unless you put spacers. 4th not a big issue but you have to redrill holes for the new tracks to match the factory ones. After all that you end up with spacers below and above the track and no great improvement. I wasted $60 and 4 hours trying every mod with them and gave up. I made my own seat mod with plates under the carpet on the floor pan. (6'1" 230 lbs). I hope this saves you the aggravation I went through. But I do got a set of aftermarket tracks that are drilled for sale!
68 Cloned RS/SS w/ all the goodies.
67 Firebird w/ a Chevy 350
67 Camaro 6 cyl. 68,000 original miles
w/ wife & kids w/ the same addiction.
68resto is offline
post #21 of 45 (permalink) Old Jan 16th, 13, 03:20 PM Thread Starter
Kip
I tried a set of the extenders, to see if it would help with my issue.... I didnt help at all... my head just hits the roof about 2" further back. Epic fail....
My next plan is to cut the tracks... Frick..!!
kv67ssrs is offline
post #22 of 45 (permalink) Old Jan 22nd, 13, 02:24 PM Thread Starter
Kip
I ended up cutting about 1.25" out of the seat track legs. Its a major PITA to get the seat bolted down again... but it made a major difference.
kv67ssrs is offline
post #23 of 45 (permalink) Old Jan 22nd, 13, 02:50 PM
Garth
Cool ! There's still enough room for side adjusting lever to work without interference ? I figured they'd be a pain to get the bolts in there, but atleast you were able to do it ! ...not like the seats need to be removed very often.
Any pics ?
post #24 of 45 (permalink) Old Jan 22nd, 13, 04:53 PM Thread Starter
Kip
Here are some pics. I had to notch the sides of the seat extenders to make room for the seat release mechanism.
Seats dont slide back and forth the as well as they did. Still working on that. But, I am willing to sacrifice that for the gained head room.
kv67ssrs is offline
post #25 of 45 (permalink) Old Feb 7th, 13, 10:14 AM Thread Starter
Kip
Update:
EPIC FAIL
with everything bolted down... seat dont slide at all. I gained a bit of headroom with the modifications, but not sure the gain was worth it.
Seats look fantastic, but the car is miserable to drive....
This has turned in to a complete cluster...
kv67ssrs is offline
post #26 of 45 (permalink) Old Feb 7th, 13, 10:56 AM
Update:
EPIC FAIL
Well you answered my question about cutting the seat track legs. I was about to get into this as I too have the TMI sport seats. I was also concerned about the adjuster lever access.
All in all, maybe I should have tried the 2002 F body seats . Power Tour coming up and this will be the real seat test for 2500 miles.
Seems next idea would be to put my old seat cushion springs back in. Its basically the bottom seat cover install , all over again.
I used new repop seat springs as I thought it was the right thing to do after 40+ years of use.
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
zdld17 is offline
post #27 of 45 (permalink) Old Feb 7th, 13, 11:15 AM
Steps
In my opion, for the 69 at least, the seats a a total design faliure.. dont hold one well in the seat, espec the front passenger and fall way short as a drivers daily driver seat or road trip.
I put my orginals awayt years ago, moded some brackets to bolt to the orginal runners, and bolted in 1988 subaru leon seats.. damn nesr the same overall diamentions, more head room, they lay right back to the rear seat and give far more room fore rear access.
And more head room.
All I did is use a bit of 12mm x 25mm bar, drilled tapped holes to bolt to the runners and another set drilled to take the seat mounting bolts, in a direction across the car..
I dumbied up the position of the bars, holes with the seat in the car....both front back, and sidways and vertiacally ...
I did miss calculate the drivers by maybe 1/4" as siding forward rubbs a bit hard against the center consol, but one would have to be 5' nothing to drive in that possition.
If u are the only person to be driving the car 99% of the time, what is the problem of fixing the seat possition height, front/ back for u ...anyone else can use a pillow IF need be.
Steptoe is offline
post #28 of 45 (permalink) Old Feb 7th, 13, 03:38 PM
Hey Forums folks -
I too, just replaced covers with TMI Sport Seats - Houndstooth. The material is very nice and I like the quality (aside from popping off button tops...).
I reused my nice factory springs, not new springs and even still I now have a bald spot on my head from rubbing the headliner!! It's really a misery. This is a bit of a fail on TMI's part. I refuse to believe that factory seats rode this tall...no way!
I think I've read about this one hundred times, TMI. I now need to throw down more big bucks for a tilt column so I can slouch forward to gain head room...not the 'performance driving experience' I was promised.
Heynow14 is offline
post #29 of 45 (permalink) Old Feb 7th, 13, 05:29 PM
Garth
Update:
EPIC FAIL
Wow, bummer ! Why doesn't the seat slide ? Where is the interference ? Is the seat all the way back now ? How much headroom did you gain...1.25 " ??
HeyNow 14, just out of curiosity, how tall are you and your build ?
One other trick that comes to mind....not that I like the idea, but it may be your last resort. You could try removing those 2 side springs on the bottom of the frame. They commonly are broke anyway. I found both were broken on my drivers seat and 1 was on the passenger seat. You can actually see it in the pic I posted, the lower cushion (original, non recovered) kinda sags on one side.
post #30 of 45 (permalink) Old Feb 8th, 13, 05:04 AM Thread Starter
Kip
Right now, I have the seats installed WITH seat extenders. However, the seats come in contact with something that keeps them from going all the way back. Not sure what, I got frustrated and quit...before I broke something...
I have thought about just installing them in a fixed position somehow...
My issue is that I shouldnt have to be going to these great lengths to make this work. This kit was designed for a 67 Camaro...it should work in a 67 Camaro irregardless of whether or not I replaced the 40 year old springs with new springs..which were
again..designed for a 67 Camaro....
kv67ssrs is offline
Human Verification
