What glue metal to vinyl - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 18th, 06, 06:39 AM Thread Starter
Question What glue metal to vinyl
On my 67 camaro replacement standard interior door panels there is a metal trim strip about 1/2 inch wide running full length of the panel that is glued to the vinyl, mine is coming loose. What is the best brand and type of glue to use to reattach the metal trim to the vinyl that will hold and not make a mess?
rfine67 is offline
post #2 of 7 (permalink) Old Apr 18th, 06, 12:01 PM
Re: What glue metal to vinyl
Try DAP WeldWood. That's what I used to affix my metal strips... has held up so far.
- '68 Chevy Camaro (sort of done, but always subject to improvement)
- '63 Pontiac Tempest (work in progress)
- '72 Datsun 240-Z (back-burner for now)
boodlefoof is offline
post #3 of 7 (permalink) Old Apr 18th, 06, 01:41 PM
While removing the dash pad from my 69 vert, I broke off a couple of the metal tabs. (the plastic backing on the pad got very brittle over the years, bewrae) I just glued them back on with Gorilla Glue and clamped them overnight. WOW....that stuff sticks to anything.
buzzworth is offline
post #4 of 7 (permalink) Old Apr 18th, 06, 02:59 PM
Alex Folino
Send a message via AIM to AlexFolino
Remember when using the gorilla glue, the stuff bubbles and squirts out white stuff.. use a little dab of the glue because it will smear out if not. The stuff works great though but keep some clean wipes handy.
GM service technician.
25 years old. I only drive chevys. Everything else and i do mean everything can rust in piece.
68 owner-The only way to go
Camaro: A small vicious animal that eats mustangs.
AlexFolino is offline
post #5 of 7 (permalink) Old Apr 18th, 06, 04:28 PM
To glue vinyl to metal,, I would use the black can of 3M adhesive spray. Lowes carries this.. Seems to be the strongest of spray adhesives but if gluing a small item like the man with the dash.. gorilla will do
TC # 349
zdld17 is online now
post #6 of 7 (permalink) Old Apr 21st, 06, 06:30 PM
Daral
I agree the Gorilla glue is good stuff. I have also used clear 100% silicone calk, the stuff you would use on your house windows. It works great when you are glueing two different types of material together. You will have to clamp the parts overnight. Once it dires it stays flexible so if the materials expand and contract differently with heat, it will move with them. It also comes in black, white, gray and several colors. Black works great on a black interior.
Daral (67 RS/SS 350)
Daral is offline
post #7 of 7 (permalink) Old Apr 21st, 06, 08:53 PM
Jimmie-Retired
The 3M will work. Spray can will work if you have larger areas to glue. It is sometimes refered to as contact cement or rubber cement. There are several brands available. I have a small bottle of Elmer's brand around all the time. It comes in maybe a 4 oz. bottle with a small applicator brush attached to the inside of the lid. Very handy for small items
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
Human Verification
"Basics of Basics" Metal finishing trim and mouldings. MARTINSR Body Shop 0 May 21st, 05 08:10 PM
welding....need help 69ss350camaro Body Shop 3 Apr 3rd, 03 02:20 PM
Expanded MARTINSR Body Shop 11 Jan 15th, 03 02:57 PM
Plug Welding Balboni Body Shop 3 Jan 4th, 03 02:35 PM
chemical stripping vs d/a sanding gerico Body Shop 10 Jun 19th, 02 03:10 PM
