TKO Sticky???? - Page 3 - Team Camaro Tech
post #31 of 52 (permalink) Old Dec 12th, 08, 04:17 PM
Shafi
Re: TKO Sticky????
Originally Posted by GMJim View Post
This is a Sticky thread and isn't really used for ongoing conversation.
Hi Jim,
What do you mean it isn't used for on-going conversation? I thought that is the point of a Sticky thread. And I wouldn't know if a PM was sent, etc. since the post is still active, unanswered, correct?
Do you still have your '69?
Keisler is offline
post #32 of 52 (permalink) Old Dec 12th, 08, 08:02 PM
Re: TKO Sticky????
Originally Posted by Keisler View Post
Hi Jim,
What do you mean it isn't used for on-going conversation? I thought that is the point of a Sticky thread. And I wouldn't know if a PM was sent, etc. since the post is still active, unanswered, correct??
Here on Team Camaro, The sticky's are used for mostly static info, though they are rarely closed. This particular sticky has been the home of a lot of extra conversation over a pretty long period of time.
And no, here on Team Camaro, a 4 month old question is not active.
post #33 of 52 (permalink) Old Dec 13th, 08, 11:59 AM
Re: TKO Sticky????
Thanks Jim
I guess that says it a little better.
GMJim is offline
post #34 of 52 (permalink) Old Apr 4th, 09, 08:19 PM
Re: TKO Sticky????
"Speedometer hook up
The TKO is set up to work with either your stock mechanical speedometer or an aftermarket electric speedometer. When using the stock mechanical speedometer gauge, the solution is to use a custom speedometer cable with an integrated adapter that is designed for use with the TKO"
So this statement means the factory speedo cable wont work.My speedo isnt working and need to try and fix
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #35 of 52 (permalink) Old Apr 4th, 09, 08:29 PM
Re: TKO Sticky????
Scott, this question would be MUCH better asked as a new thread, rather than tagging onto this sticky post.
My TKO came with a speedo bullet that fit the original Camaro cable.
I has a lil short adapter thing in it that fits onto the camaro speedo cable and into the tko/Ford speedo gear.
post #36 of 52 (permalink) Old Apr 5th, 09, 08:34 PM
Re: TKO Sticky????
I thought I'd ad this after Scott's question above. I don't recall any discussion on speedo cables. Mine (which I bought used) came from Mike Pell, and uses this adapter. It still uses a Ford speedo gear, and the Camaro cable screws right on.
post #37 of 52 (permalink) Old Jun 21st, 09, 07:13 AM
charlie
Re: TKO Sticky????
i have a tko 600 in my camaro, love the overdrive!! the only problem i have w/ it is when trying to speed shift it, i can shift every gear w/ no problem other then 2-3 shift, it always misses it, i am using the stock shifter turned 180 degrees w/ an original style hurst shift arm bolted to it, thanks!!!
actmobmar is offline
post #38 of 52 (permalink) Old Jul 18th, 09, 03:57 PM
Re: TKO Sticky????
I wanna run a tremec 600 in my 550 hp chevy but hear they don't shift.Does the Liberty mods make it shift floor board deep AND be able to downshift as a street car needs? Sell me one that will shift-downshift-hold up to 600 ft lbs/hp...
Redline Racer is offline
post #39 of 52 (permalink) Old Jul 18th, 09, 07:57 PM
Re: TKO Sticky????
I wonder if the mods Liberty performs ( not faceplate)makes this trans usable for shifts at 7000 + rpm and still be able to downshift as needed for street driving.
post #40 of 52 (permalink) Old Jul 19th, 09, 09:17 PM
Zach
Re: TKO Sticky????
Want to run the tko 600 behind my lsx engine in a 68 camaro.. Is there a crossmember that works with the ATS engine mounts? or any mounts?.. What throwout, bellhousing, clutch package would work with this.. I have a later camaro slave cylinder in it already...
Anyone know??
zschary is offline
post #41 of 52 (permalink) Old Mar 21st, 10, 12:13 PM
Re: TKO Sticky????
opps
post #42 of 52 (permalink) Old Jun 15th, 10, 08:52 PM
Doug
Re: TKO Sticky????
I have installed a TKO 600 in my 69 using a Lakewood scattershield which at this point I am thinking was a bad mistake. Originally I installed the scattershield without dialing it in.
Car had a annoying drivetrain vibration. Pulled tranny and indexed as required. Put back together and the vibration is gone. Problem solved, well not so quick. It now seems as though as components heat up the vibration comes back. How likely is it that the scattershield is distorting as it heats up? Is anyone having problems with Lakewood Scattershields? Who is making the best Scattershield/bell housing at this time?
chug is offline
post #43 of 52 (permalink) Old Aug 11th, 10, 03:37 PM
click's Avatar
Re: TKO Sticky????
zschary and Chug you guys need to start your own individual threads with your own questions. They will be lost in this thread.
Start new threads and the folks will be happy to give you their advice.
click is offline
post #44 of 52 (permalink) Old Feb 16th, 11, 11:39 AM
Tim
Re: TKO Sticky????
No one answered you in three months ...
This is a design of T56 that uses remote shifter which is attached to the transmission using strut arms with bushings. This is required because many newer RWD cars, incl Mustang, CTS-V, GTO.
While something could probably be rigged up a gen 1 or 2, it would be time consuming and the result would be inferior to a more standard approach, like our T56 PerfectFit kit.
Check out this thread and you can pull up a large image of the T56 PerfectFit kit.
I replied to your other thread a moment ago, and mentioned you should look at the Blue T45RS kit for $1299. (see image below)
Keisler offers a perfectfit RS400 kit for 2nd gen camaros
including a custom crossmember per the Keisler web site.
However the crossmember has yet to be designed...really? Why
advertise something that is not in production?
spaz1096 is offline
post #45 of 52 (permalink) Old Jun 4th, 11, 12:46 PM
Daniel
Re: TKO Sticky????
The OP needs to add dexron III / Mercon spec ATF as recommended (and warranty compliance) oil, as stated by Tremec:
We recommend GM synchromesh part # 12345349, or Dexron III / Mercon Spec ATF fluid for all TKO transmissions.
Link to their PDF online which also ships with every transmission:
http://www.ttcautomotive.com/english...ps_117_117.pdf
sweetblue69 is offline
Human Verification
Big cams and TKO 600's 6D9 Performance 21 Oct 9th, 06 07:33 AM
First drive with new TKO 600 DarcyW Transmission & Driveline 2 Sep 21st, 06 08:18 PM
TKO nuetral safety wiring Mike68RS Electrical & Wiring 3 Feb 13th, 06 06:36 PM
Comprehensive TKO transmission guide for first gen Camaros - part 1 Hurst - Jeff Transmission & Driveline 2 Jan 28th, 06 10:51 AM
TKO crossmember update Eric Kammerer Transmission & Driveline 9 Apr 30th, 05 05:11 PM
