Muncie trans decoding - Team Camaro Tech
post #1 of 2 (permalink) Old May 17th, 07, 07:18 AM Thread Starter
Robert
I cannot figure out what trans I have. Any help would be apreciated!!
Main case casting # 392566 There is no Zero at the end.
Tail stock casting # 3857584
Main case stamped # poc12a
Side cover 39552648. The side cover uses bolts for the shift linkage. Also has a swicth that threads into cover at the botton of the front shift arm.
Any help please.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
68Holdon is offline
post #2 of 2 (permalink) Old May 17th, 07, 06:06 PM
JohnZ's Avatar
Re: Muncie trans decoding
1970 Muncie M-20; the switch on the 3-4 shifter shaft boss is for the TCS (Transmission Controlled Spark) system.
JohnZ
CRG
'69 Z/28 Fathom Green
JohnZ is offline
Human Verification
Switch from Hearst to Muncie shifter? erik67ssrs Transmission & Driveline 13 Feb 3rd, 07 08:12 AM
need help id a Muncie 4speed trans dgmz28 Transmission & Driveline 2 Dec 10th, 06 12:19 AM
Muncie trans decode help needed South Side Goons & Hitmen Transmission & Driveline 10 Oct 30th, 06 03:42 PM
Muncie Trans Rebuild Motorhead62 Transmission & Driveline 12 Oct 31st, 05 06:53 PM
muncie trans tim muscio Tech 2000 1 Nov 18th, 00 02:58 PM
