3 series vs 4 series carrier - how to distinguish - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 13th, 07, 06:15 AM Thread Starter
Greg
Just as the header says, on a 12 bolt 4.56 Posi, how do you distinguish between a 3 series carrier and 4 series carrier with the cover off?
I understand that it is more than likely a 4 series due to the gearing, but would like to validate 'more than likely'.
If anyone has pictures of the two that would be great. I don't see any brand name on the gears, just '41 9' (for the tooth count of ring/pinion) and USA. There were some numbers on the side of the carrier, that are hard to see, I did not write down.
Thanks in Advance!
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #2 of 10 (permalink) Old Nov 13th, 07, 06:38 AM
Re: 3 series vs 4 series carrier - how to distinguish
If it's got 4.56 gears on it and it's installed in a housing, it sure isn't going to be a 3-series carrier unless you've got a spacer or a real thick gear. The break is between 3.73 and 3.90, and you're well over that. You might call West Coast Differentials, they'll have all the numbers you need. 800-510-0950
onovakind67 is offline
post #3 of 10 (permalink) Old Nov 13th, 07, 07:22 AM
Charlie
The way it was told to me, anything over a 3.90 gear uses a 4 series carrier. Below 3.90 uses a 3 series carrier.
67CamaroRS/SS is offline
post #4 of 10 (permalink) Old Nov 13th, 07, 08:49 AM
Ron
You can buy 4.11 and 4.56 gears to fit a 3 series carrier withiut a spacer.
rontoomanyprojects is offline
post #5 of 10 (permalink) Old Nov 13th, 07, 09:02 AM
Smile Re: 3 series vs 4 series carrier - how to distinguish
You can also buy 3.73 gears for a 4-series carrier. Strange engineering has an excellent photo on how to tell the difference between a 3 and a 4 series carrier. Their catalog is at this link...http://www.strangeengineering.net/catalog/index.html goto page 26 in their catalog.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #6 of 10 (permalink) Old Nov 13th, 07, 09:07 PM Thread Starter
Greg
Mystery Solved!
Thanks for all your inputs.
TJS69 that picture was spot on what I needed to comprehend.
I made the measurements, and immediately (since I knew what to look for now) spotted a crude, machine stamped spacer. The spacer measured ~.300, and had machining stamp scars on the OD. The ring gear and carrier were smooth. The carrier measured 1". The spacer is sandwiched between the carrier and ring gear. The measurements are indictative of a 3 series carrier.
I also was able to read the carrier number - EDB 30140...just googled that, and it is jumping out on several forums as a 3 series carrier. There are also references to the spacers with OD scars.
So good news for me, I can buy the gearset I really want (3.55) and use my old carrier!!
1969 RS/SS Vert
chops is offline
post #7 of 10 (permalink) Old Nov 13th, 07, 09:12 PM Thread Starter
Greg
And now for a more realistic pic
1969 RS/SS Vert
chops is offline
post #8 of 10 (permalink) Old Nov 14th, 07, 01:33 PM
Jeff
I miss B.G.H. !!!
SC42 is offline
post #9 of 10 (permalink) Old Nov 14th, 07, 06:43 PM
Jake-68's rule
When you have the carrier out, use BraKleen and clean out the oil passages, the two holes outboard of the bearing caps, and clean out the sediment.
Along with the cover, see the groove, the ring gear splashes oil into these passages and lubes the carrier bearings. Over the years, the passages become restricted.
I don't know if the dealer sells them any more, but get a set of 75 lb springs, yellow in color to replace the 50 lb. green springs. These new springs will make the carrier act like a spool.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
post #10 of 10 (permalink) Old Nov 14th, 07, 06:53 PM
last 3 digits of a 3 series are ....140 last 3 digits of 4 series are...174. This is from memory but i believe is correct.
Ryan
ssscamaro is offline
Human Verification
