replacing a 700r4 with a turbo 400 - Team Camaro Tech
post #1 of 17 (permalink) Old May 7th, 08, 06:55 AM Thread Starter
keith
I need help! I have a 85 camaro original trans was a 700r4 and now going to replace it with a turbo 400. Has anybody done this ? and what has to be done with the crossmember ?
kapshots is offline
post #2 of 17 (permalink) Old May 7th, 08, 08:11 AM
Woodstock
Re: replacing a 700r4 with a turbo 400
I don't know why you would do that!
I am replacing the PG in my 67 Camaro and the 400 in my 70 Chevelle with a 700R4.
With a 400 in your car it will be a dog off the line and you will loose overdrive and burn a lot more gas.
Keep the 700R4
If you do change it you will need a new cross member and drive shaft as the 400 is shorter than the 700.
Sick Old Man with more money than brains.
1971 Demon 440 BB
1970 Chevelle SS 454
1967 Camaro Red SS 350
1967 Camaro Black # match 327
sburdy is offline
post #3 of 17 (permalink) Old May 7th, 08, 10:21 AM Thread Starter
keith
the 700r4 has 180,000 miles on it and the turbo 400 is a brand new TCI super street fighter.
kapshots is offline
post #4 of 17 (permalink) Old May 7th, 08, 10:38 AM
Kevin
KevinW's Avatar
Get a built 700r4 to handle your horsepower, the th400 will involve too many changes to make the swap economical.
Kevin
KevinW is offline
post #5 of 17 (permalink) Old May 7th, 08, 10:57 AM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
http://www.thirdgen.org/techboard/tr...arts-list.html
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #6 of 17 (permalink) Old May 7th, 08, 11:00 AM
Greg
Just have the 700r rebuilt for performance.
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
emperor91108 is offline
post #7 of 17 (permalink) Old May 7th, 08, 12:01 PM
Fred
Can't speak for the ease of the swap, but that 400 setup is similar to what mine is now. Be sure to budget for a NECKBRACE! Dog? NOT!
128.79mph 1.428 60'
Fred Ficarra is offline
post #8 of 17 (permalink) Old May 7th, 08, 08:04 PM
Woodstock
GEAR RATIOS OF THE TH-7004R
FIRST GEAR SECOND GEAR THIRD GEAR FOURTH GEAR
3.06:1 1.63:1 1:1 0.70:1
GEAR RATIOS OF THE TH-350
2.52:1 1.52:1 1:1 N/A
GEAR RATIOS OF THE TH-400
2.48:1 1.48:1 1:1 N/A
You can see that the 700R4 would launch much harder with the steeper first gear.
One man's dog is another man thoroughbred.
Sorry man the numbers don't lie!!!!
1971 Demon 440 BB
sburdy is offline
post #9 of 17 (permalink) Old May 8th, 08, 11:29 AM Thread Starter
keith
anybody want to buy a TCI turbo 400 never used never installed ?
kapshots is offline
post #10 of 17 (permalink) Old May 8th, 08, 01:47 PM
Fred
oops, messed-up, see below.
128.79mph 1.428 60'
post #11 of 17 (permalink) Old May 8th, 08, 01:51 PM
Fred
There's numbers and then there's numbers. A TH400 is a BB trany designed to stand up to the pounding and torque that big blocks produce. As Hotrod Magazine said, if you've got a big-inch engine in front of a TH400 and want overdrive, don't replace it with a weaker 700R-4. Instead, consider an add-on overdrive such as from GearVendors. Hard to beat a TH400. Those gears are there for a reason. I'm no engineer so I won't go there but I sure wish I had something other than a 700R4 in my old 4X4. It can't take the load. It's on its third replacement behind a SMALL block! My TH400 has never needed a penny spent for repairs in nearly 40 years behind a very strong BBC. That number is even harder to beat. And I need a neck brace at the drags.
128.79mph 1.428 60'
post #12 of 17 (permalink) Old May 8th, 08, 04:51 PM
Mike Petrovich
The value of overdrive is related to your axle gear and amount of highway use. The value of transmission first gear is related to your axle gear and engine power. Lots of racers use Powerglide or TH400 transmissions.
1968 327 sport coupe. Son of original owner.
mike p is offline
post #13 of 17 (permalink) Old May 9th, 08, 01:19 PM Thread Starter
keith
The rear is stock for now and don`t plan on doing a whole lot of highway driving ,more of a weekend drag car
kapshots is offline
post #14 of 17 (permalink) Old May 10th, 08, 12:32 PM
Fred
Then skip the overdrive on your TH400.
128.79mph 1.428 60'
post #15 of 17 (permalink) Old May 13th, 08, 05:28 AM Thread Starter
keith
I really need to know what I would need to do to make this swap happen, The TCI turbo 400 super street fighter was bought for $650 brand new, that`s why I want to change it out, the stock gears in the rear will be changed at a later date . I do appreciate everybodys input so far
kapshots is offline
Human Verification
