1969 Camaro Convert Auto to Manual - Team Camaro Tech
post #1 of 6 (permalink) Old May 12th, 08, 04:30 PM Thread Starter
Road/Christian
Budget is the key. Looking to spend $800-1000 total so Tremec is out. What components?. Trans, bell housing, clutch, shifter, pedals, z bar, crossmember, driveshaft. Anything else. Car is a 350/350 car currently.
1969 Camaro- My Fav.
2001 Silverado- Tow mule/DD
1986 Toyota- Off road truck
2005 Hummer H2 on 37's- wifes monster
All vehicles Black
b.w.t.road is offline
post #2 of 6 (permalink) Old May 12th, 08, 05:53 PM
Kevin
KevinW's Avatar
Re: 1969 Camaro Convert Auto to Manual
If you stick a muncie in, then you can re-used the crossmember and driveshaft. You will need a longer speedo cable. If you have a console, you will need a few parts there, boot, plate, etc.
Kevin
KevinW is offline
post #3 of 6 (permalink) Old May 12th, 08, 06:14 PM
Rob
It has been talked about recently.
Changing an Auto to 4 Speed???
hypersport750 is offline
post #4 of 6 (permalink) Old May 13th, 08, 10:56 AM
check out my thread. it might be helpful.
Tips to install a BW Super T-10 in a auto '67
1967 rs conv. hugger orange, 350 engine, former turbo 350 tranny-now SUPER T-10!!
1969 blue SS 'vert, 350 engine, 4 spd
DROPTOPtimes2 is offline
post #5 of 6 (permalink) Old May 13th, 08, 06:59 PM
Originally Posted by KevinW View Post
You will need a longer speedo cable..
If you find a trans that has a drivers side speedo (a non-camaro trans) your existing speedo cable will fit.
Make sure the trans is a coarse spline input shaft (10 spline)
I did a PG to muncie swap years ago for a grand, found the trans on ebay for around $400, new hurst shifter and install kit ate up $250, found a used bell on ebay cheap, used flywheel cheap, new pedals, linkage, and clutch.
post #6 of 6 (permalink) Old May 13th, 08, 08:38 PM
I think you better double your budget to get that job done, now. As Jim said years ago.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
Human Verification
