94 Z28 trans removal - Team Camaro Tech
post #1 of 8 (permalink) Old May 21st, 08, 03:15 PM Thread Starter
James
It's a six speed. We took out four bolts on the bellhousing. Are there any more? It's as if it's still hooked up, but we can't see any.
Help us get this thing out!
Thanks in advance!
James Z28 is offline
post #2 of 8 (permalink) Old May 21st, 08, 04:13 PM
Re: 94 Z28 trans removal
The shift fork is bolted to the transmission and hangs onto the throwout bearing, which causes the transmission to only slide out an inch or so before getting hung up. This will need to be unbolted if you haven't already done so.
Thanks in advance!
67 RS/SS clone - 530rwhp
11.15@125mph
http://www.fquick.com/tlenzi
redcamaro is offline
post #3 of 8 (permalink) Old May 21st, 08, 04:32 PM Thread Starter
James
Did we maybe miss a bolt on the bell housing? We took out four.
post #4 of 8 (permalink) Old May 21st, 08, 04:35 PM Thread Starter
James
We didnt get the transmission off the engine yet thats the problem.
post #5 of 8 (permalink) Old May 21st, 08, 08:42 PM
byrdman
1. Disconnect battery ground cable, then remove front floor console trim plate assembly.
2. Remove control lever handle, then raise and support vehicle.
3. Drain fluid from transmission, then support rear axle assembly with a jack stand.
4. Disconnect propeller shaft assembly, then remove rear axle torque arm.
5. Remove catalytic converter hanger assembly, then disconnect electrical connectors from back-up lamp switch and reverse lockout solenoid.
6. Disconnect clutch master cylinder push rod from clutch pedal assembly, then remove clutch actuator cylinder and retain with mechanics wire.
7. Remove actuator spacer, then pull clutch fork assembly down to disengage release bearing.
8. Disconnect electrical connector from electronic speed sensor, then support engine assembly with a jack stand.
9. Support transmission assembly with a jack stand, then remove transmission support and mount assembly.
10. Remove transmission assembly.
11. Reverse procedure to install. Torque transmission bolts to 26 ft. lbs. , actuator cylinder nuts to 15 ft. lbs. and transmission control lever handle bolts to 18 ft. lbs.
1967 rs all original except drive train 30 over 327 2.02 valve 67 heads 86 camaro TPI top end, 700r4
1957 Bel Air 2dr hdtp resto mod show and go
64 chevy deuce 327, 350
people treat you like you let them
67rs57belair64chevyll is offline
post #6 of 8 (permalink) Old May 22nd, 08, 08:11 AM
I think there are 8 bolts total that hold the transmission to the bellhousing.
11.15@125mph
post #7 of 8 (permalink) Old May 22nd, 08, 08:27 PM
byrdman
six bolts bellhousing to block two on either side straight above one another then one on each side on the angle
post #8 of 8 (permalink) Old May 23rd, 08, 02:48 PM Thread Starter
James
ok found all 8 bolts from transmission to the bellhousing. new problem tranny wont come off. any suggestions???
Human Verification
