1970 Muncie 4 speed??? - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 14th, 09, 08:23 AM Thread Starter
Trying to determine what I need to change to install a 1970 Muncie transmission (P0A05A) with extension housing casting number 3978764 in a 1969 Camaro. The '69 needs a 3857584 extension housing for the correct shifter??? Is this a '70 transmission that had a different extension and mainshaft installed? The mainshaft has the fine splines.
AJL69 is offline
post #2 of 8 (permalink) Old Aug 14th, 09, 03:30 PM
Banned
Re: 1970 Muncie 4 speed???
I may be off here, but I don't recall our Muncies having different tail-housings?? What side is the speedo end on?
In and out spline counts are course for the early years and fine for the later years here is all.
Jump right in guys..
pdq67
post #3 of 8 (permalink) Old Aug 14th, 09, 05:08 PM
I'm not a part number guy, but...
There were a few different muncie tailhousings. firstgens came with a short - pass side speedo.
Most everything else came with a short - drivers side speedo.
Some big cars came with a long tailshaft.
As long as it's a short tailshaft, it will fit.
drivers side speedo is actaully easier, just use a speedo cable for that year camaro with a powerglide or t350.
powerglide or t350 crossmember and drivershaft will fit.
yoke could be different, fine spline muncie's might have a different spline output shaft too (someone will know and post up)
fine spline clutch is not a problem, just get one it will fit.
The right hurst aftermarket shifter will bolt on to the short tailshaft.
post #4 of 8 (permalink) Old Aug 14th, 09, 08:40 PM
Ron
This is my 70 Z28 M21 Muncie, it has various Bosses in the tail extension to mount the Hurst shifter using a base plate mounting bracket original to the 70.
Note the Mounting Bosses on the tail housing to locate the Shifter's mounting Plate.
I know th PIC run out there but I believe you can see most oft it. You should be able to mount this tranny in the 69 and locate the shifter where you want it.
I love this PIC
Note the Fan Belt and hoses on the engine - Talk about anticipation ;o)
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 8 (permalink) Old Aug 14th, 09, 09:34 PM
Chris
Great picture! Love it!
Chris
72 Camaro RS/SS, 383, Dart Heads
Bucco47 is offline
post #6 of 8 (permalink) Old Aug 15th, 09, 08:42 AM
Isn't the 764 tailhousing for the fine 32 spline 70+ trans? It will still fit, but you'll need a different clutch and driveshaft with a 400 yoke.
go2fast is offline
post #7 of 8 (permalink) Old Aug 15th, 09, 06:42 PM
Ron
Correct the Yoke and Drive Shaft length will have to be changed but the Mounting and Shifter Rod length will remain the same.
Z15CAM is offline
post #8 of 8 (permalink) Old Aug 15th, 09, 07:43 PM
Jody
The 764 tail extension shifter mount bracket bolt pattern is different than the 584 tail extension shifter mount bolt pattern.
Crashent a member here manufactures a conversion shifter mounting bracket to use a 764 tail extension in a '69 Camaro.
Jody Haag
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
JodysTransmissions is offline
Human Verification
