4 speed neutral safety switch - Team Camaro Tech
post #1 of 14 (permalink) Old Mar 14th, 10, 06:04 PM Thread Starter
DT
Donny
DT's Avatar
Would anyone have a picture of a 69 4 speed neutral safety switch's location ?? I'm sure it has to be mounted in a location in the console so the shifter handle can make contact with it to activate the reverse lights.
DT is offline
post #2 of 14 (permalink) Old Mar 14th, 10, 06:17 PM
Daryl
1968RallySport's Avatar
Re: 4 speed neutral safety switch
The neutral starting switch was clutch-operated in 1969. I can send you a picture via email if you need one. It's mounted up under the dash.
1968RallySport is offline
post #3 of 14 (permalink) Old Mar 14th, 10, 06:27 PM Thread Starter
DT
Donny
DT's Avatar
Thanks Daryl, not the Start switch which I know is clutch activated. The neutral saftey switch. I'm certain its mounted inside the center console.
DT is offline
post #4 of 14 (permalink) Old Mar 14th, 10, 06:32 PM
Daryl
I'm confused. When you say "neutral safety" what else is there besides the start circuit. The clutch switch is all there is. No reason to have two switches.
post #5 of 14 (permalink) Old Mar 14th, 10, 06:32 PM
Donny,
The term "neutral safety switch" is really not correct for a manual trans car. They have a clutch safety switch which will not allow the starter to work without the clutch pedal being pushed in.
As far as the backup lights go, if I am not mistaking, the 69's are the same as my 71. The backup light switch is part of the steering column assembly. If your key is in the column this is the way it is. There should be a linkage from the reverse lever on the trans that goes up towards the front of the car to a bellcrank, then up the firewall and connects to a lever at the base of the steering column. It is the same mechanism that turns the column so that you can remove the key in reverse.
Here is a picture of the switch:
Name:	backup switch.jpg
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 14 (permalink) Old Mar 14th, 10, 06:39 PM
Donny,
I am having a brain fade here and thinking we are talking about Chevelles But I am pretty sure the Camaro is the same way ??
http://www.shop.stevescamaroparts.co...tch-092912.htm
http://www.shop.stevescamaroparts.co...ars-261080.htm
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #7 of 14 (permalink) Old Mar 14th, 10, 08:30 PM Thread Starter
DT
Donny
DT's Avatar
There is a neutral start switch and a Neutral safety switch. As mentioned above by Bill, I now realize the neutral safety switch is on the steering column. The start switch is on the clutch linkage.
http://www.ss396.com/mm5/merchant.mv...RALSTARTSWITCH
http://www.ss396.com/mm5/merchant.mv...ct_Code=GNS-33
DT is offline
post #8 of 14 (permalink) Old Mar 14th, 10, 08:39 PM
Ron
There is no such thing as a Neutral Safety Switch for a Manual Transmission. 2 things are required to engage the Starter #1 - Key is turned to Start and #2 The Clutch Petal has to be Depressed to the Floor which activates a Secondary Switch to complete the circuit to engage the Solenoid.
What good would a Neutral Safety Switch be if you had to Bump Start your Ride that has a Manual Transmission with the Key in Run Position.
Automatics have a Park and Neutral Safety Switch but will Bump Start at approx 40Mph by placing the transmission into 2nd with the Key in the Run Position.
This was my 70 1/2 Z28
Z15CAM is offline
post #9 of 14 (permalink) Old Mar 14th, 10, 08:43 PM Thread Starter
DT
Donny
DT's Avatar
Check out the above links. It shows a neutral safety switch for 4 speeds???
DT is offline
post #10 of 14 (permalink) Old Mar 15th, 10, 04:20 AM
Jake-68's rule
Bottom link "GNS-33" is reverse back-up light switch for a "69 manual trans.
Right part, wrong box.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
post #11 of 14 (permalink) Old Mar 15th, 10, 05:00 AM
Donny -
pics of my 69 clutch safety switch in this thread: 69 Camaro Manual Trans Neutral Safety Switch
Eric
Eric Kammerer is offline
post #12 of 14 (permalink) Old Mar 15th, 10, 05:09 AM
Donny,
I will have to look in my GM parts book this evening, but I dont think GM ever called it a neutral safety switch. I think the term has just been used for so long by the aftermarket that it has caught on.
If you think about it, the switch has absolutely nothing to do with "neutral" in a manual transmission car. Why would you call it a "neutral" safety switch ?
Bill Koustenis
Owner
Waldorf Md
BillK is offline
post #13 of 14 (permalink) Old Mar 15th, 10, 10:33 AM Thread Starter
DT
Donny
DT's Avatar
No I agree, it completely confused the heck out of me?? Thanks Bill.
DT is offline
post #14 of 14 (permalink) Old Mar 15th, 10, 10:35 AM Thread Starter
DT
Donny
DT's Avatar
Originally Posted by Eric Kammerer View Post
Donny -
Thanks Eric.
DT is offline
Human Verification
