Clutch Fork Return Spring - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 22nd, 13, 12:14 PM Thread Starter
Tony
Hey guys, can you tell me the purpose of the clutch fork return spring? I was talking to a guy at a local car show and he said you don't need it. I'm thinking that it would be used to keep the throw out bearing from riding on the clutch or something.
Thanks,
tonyvol is offline
post #2 of 4 (permalink) Old Apr 22nd, 13, 12:21 PM
Camarodude67
Re: Clutch Fork Return Spring
You need it or the Z-Bar rod will fall off, trust me, it happened to me on was stuck on the side of the road and the spring connects to
frame mount if possible.
Jeff G.
camarodude67 is offline
post #3 of 4 (permalink) Old Apr 22nd, 13, 12:25 PM
Jeff
Yes, it is to keep the throwout bearing off of the pressure plate finger springs. If you look at the AIM, it will show the process for setting up the free play (how much the t/o bearing is pulled away from the pressure plate).
Now, some manufacturers had the t/o bearing riding constantly against the pressure plate. The idea was that the bearing wouldn't undergo lots of start/stop cycles, which would make it last longer. Maybe that's what the guy at the show was thinking of.
jeff68 is offline
post #4 of 4 (permalink) Old Apr 22nd, 13, 06:16 PM Thread Starter
Tony
Thanks Jeff and Jeff for the reply back. I'll keep the spring. I was woundering if it was needed since I have headers and need to attach the spring them.
tonyvol is offline
Human Verification
