Best automatic transmission to use with 502 Crate engine - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 29th, 13, 01:49 PM Thread Starter
Lyle
Any ideas on what auto transmission would be best to use behind a chevy crate 502 engine in a 68 camaro? Also, curious about what torque converter would be best. We were thinking of gears in the area of 350's for best all around performance with a 12 bolt, or should we be using a ford 9"?. Any ideas? Thanks!
moparmusclecars is offline
post #2 of 4 (permalink) Old Sep 29th, 13, 11:50 PM
Re: Best automatic transmission to use with 502 Crate engine
For just bombing around town, a TH400. If you want overdrive, then a 4L80E, which is essentially an overdrive version of the TH400 and a lot more dough as it's a computer controlled trans and you need a controller for it. Neat though. Please don't put a Ford part in your Chevy - a 12 bolt will be just fine. Converter choice depends on your planned use.
BPOS is offline
post #3 of 4 (permalink) Old Oct 9th, 13, 07:01 PM
Maurice
Im putting a ZZ502 in my 68 Camaro. I have a performance built 4L80 with a lock-up converter that is manually shifted and has a mechanical speedo drive tail stock. I will run a 12 bolt with 3:73 gears.
I wanted the strongest 4 speed automatic I could find and the 4L80 is it. I will run a 2500 lock-up converter as well.
I got my 4L80 from Phoenix Transmission in AZ. I would have had it built locally but I don't know any good performance trans builders anymore.
the guys at Phoenix trans are very helpful with tech info, and the trans also has a pretty good warranty.
BE different....ACT normal.
No one is completely useless..They can always be used as a bad example
68zz502fi is offline
post #4 of 4 (permalink) Old Oct 10th, 13, 02:48 PM
DT
Donny
DT's Avatar
X2 on the TH 400. If your budget permits, def go with the 4L80.
1969 X66 396 LeMans Blue, M20, 373 ...
1969 Convertible (just arrived)
DT is online now
Human Verification
