Brown Transmission Alignment Tool - Team Camaro Tech
post #1 of 11 (permalink) Old Feb 15th, 17, 06:49 PM Thread Starter
Who has one to rent? Sell?
http://www.camaros.org/images/bellho...haft_Mount.jpg
TC # 349
zdld17 is offline
post #2 of 11 (permalink) Old Feb 16th, 17, 08:40 AM
Re: Brown Transmission Alignment Tool
Bellhousing alignment tool my friend.
HawkX66 is offline
post #3 of 11 (permalink) Old Feb 16th, 17, 09:02 AM Thread Starter
Dave, if you know of one that can be rented or bought, might contact BSCHNUR on this site, he is trying to install a tko and wants all info he can get .
thanks
TC # 349
zdld17 is offline
post #4 of 11 (permalink) Old Feb 16th, 17, 10:02 AM
At the risk of asking the dumb question, if that thing is aluminum what good is it? What can it possibly do that you cant do with a mag base dial indicator? and if its aluminum how do you strap a indicator on it to run a check on the trans mating surface?
3d cad is offline
post #5 of 11 (permalink) Old Feb 16th, 17, 06:28 PM
BonzoHansen's Avatar
Maybe jody will pop in. I got the impression those dont work as advertised.
TC Member #13
BonzoHansen is offline
post #6 of 11 (permalink) Old Feb 16th, 17, 07:08 PM
Chris
The Browell tool is a go-no go tool. You mount it to the CS and fit the BH over it eliminating the aggravation of using the dial indicator to check the runout. The BH will either fit or not, if not, the offset dowels will be needed. However, the dial indicator will give you the necessary measurements for the offset dowels (offset required and clock direction) whereas I don't see how the Browell tool can provide this same information, it only lets you know if the BH runout is within spec or not. Additionally, I don't believe that the Browell tool provides any method of checking the parallel fit of the BH to the block which should be done first before checking the runout so you'll still lneed the dial indicator. I attached a photo of the tool in the thread at the link below:
TKO 600 install questions
'69 Z/28, Lemans Blue/White Stripes, DZ302, T56 Mag., 4.10
Dynatech, 17" VWW V45's 235/45, 275/40
ctcz28 is offline
post #7 of 11 (permalink) Old Feb 16th, 17, 08:37 PM
I suppose it depends on whether you consider the indicator to be an aggravation. To me the place to start is a surface plate with the bellhousing and find out how lucky you are. Then bolt it on the block and discover if block mounting surface is perpendicular to the crank centerline. After that you can worry about concentricity.
3d cad is offline
post #8 of 11 (permalink) Old Feb 17th, 17, 05:28 AM
Wendell
I don't see how it could replace a test dial indicator? Maybe I'm missing something.
1967RS
wendell is offline
post #9 of 11 (permalink) Old Feb 17th, 17, 05:30 AM
Vega$69's Avatar
It's a go/no go. They work just fine
Vega$69 is offline
post #10 of 11 (permalink) Old Feb 17th, 17, 06:23 AM
thanks
Sorry Bud, I don't.
HawkX66 is offline
post #11 of 11 (permalink) Old Feb 27th, 17, 11:35 AM
Jody
I did an A/B test with this tool and a dial indicator. The parallel alignment was out and I had a .014" concentric reading, but the tool slid into the bellhousing retainer hole. This tool is a "go/no go" tool, but a "no go" in my tool box.
Jody Haag
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
JodysTransmissions is offline
Human Verification
