OEM Muncie Shift Lever Bushings - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Apr 17th, 17, 06:07 AM Thread Starter
Harold
I was wondering what people do to replace the molded on rubber bushings in the OEM shift levers on a Munice 4spd. If the molded rubber deteriorates do you just remove it and just have metal to metal contact and use grease? Drill out to have Hurst steel bushings pressed in?
Name:	s-l500 (Small).jpg
silverbullet07 is offline
post #2 of 16 (permalink) Old Apr 17th, 17, 06:30 AM
Chad
cv2065's Avatar
Re: OEM Muncie Shift Lever Bushings
I used these when I rebuilt mine. No grease. Although it does say that they do not replace the rubber factory bushings, so not sure if you can pull those and use these but thought I'd mention it.
Hardened Steel Bushing and Clip Kit - Hurst Shifter
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #3 of 16 (permalink) Old Apr 17th, 17, 07:36 AM Thread Starter
Harold
Yes they are to big for the OEM hole. So I was wondering if some people drilled and pressed these in or go without or found proper rubber bushing.
post #4 of 16 (permalink) Old Apr 17th, 17, 10:15 AM
I just buy new rubbers.
Mark 1970 Z28 M22 3.73 Z21 Z87 - Lunati 20120121 Retrofit Roller Cam
Owned: 1968 Z/28 in '74. 1971 Z28 from '75-'77 4-spd
Ordered new Z28's in 1977, 1978 & 1980, all 4-spds.
1970 Z28 owned since 1981
COPO is offline
post #5 of 16 (permalink) Old Apr 18th, 17, 12:22 PM Thread Starter
Harold
Where? I can not find correct ones.
post #6 of 16 (permalink) Old Apr 18th, 17, 12:39 PM
Won't these work?
or
HURST 1010006 4 Speed Adapter Bushing Bushings (set of 3) Used in KIT 3738616 | eBay
COPO is offline
post #7 of 16 (permalink) Old Apr 18th, 17, 03:25 PM Thread Starter
Harold
The oem hole is smaller and the hurst bushing and that rubber bushing is to large. Tried that already which is the reason for this post. The oem holes were smaller and had these rubber bushing molded in.
Just does not have any thing for the OEM components.
post #8 of 16 (permalink) Old Apr 18th, 17, 07:29 PM
Time to drill it out and use the nylon bushings.
COPO is offline
post #9 of 16 (permalink) Old Apr 19th, 17, 10:30 AM
Don't permanently alter your nice levers-Call Scott at Hurstshiftersonline.com. I think he has the right pieces available to repair these:
https://www.hurstshiftersonline.com/...Set-53p315.htm
HawkX66 likes this.
tangobravo is offline
post #10 of 16 (permalink) Old Apr 19th, 17, 11:06 AM
I can't believe no one has come up with a fix for this yet besides $35 oem style rubber grommets... Such an easy thing for a machinist.
'69 SS396 X66 L34 08D M21 BS
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
post #11 of 16 (permalink) Old Apr 19th, 17, 12:42 PM Thread Starter
Harold
I contacted Scott and he does not have anything for them. The levers and shifting arms were all made by GM. Hurst only supplies the shifter, he said. He has something close by looks but he says they do not fit.
post #12 of 16 (permalink) Old Apr 19th, 17, 03:59 PM
You might try contacting Pete Serio as another source. He may have a solution for you. Think I'd get some other arms before carving on those nice originals.Precision Pontiac Home Page
post #13 of 16 (permalink) Old Apr 19th, 17, 07:03 PM Thread Starter
Harold
Thanks. Yes these arms are super and do not need anything but my reverse is bare. I did not show it because it may confuse everyone here, you probable never seen one like it. It is a one year only for a 68 Firebird.
I'll contact precision and see what he says.
post #14 of 16 (permalink) Old Apr 20th, 17, 04:57 AM Thread Starter
Harold
Better picture of what I have.
post #15 of 16 (permalink) Old Apr 20th, 17, 08:45 AM Thread Starter
Harold
Still trying to get the images to show from URL.
Human Verification
