Kick down switch - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 19th, 17, 09:50 PM Thread Starter
Frank
Kick down switch
I am trying to locate the switch as the prior owner of my car lost it. I have been on ebay but no luck, there was 1 at $1,500 with out the bracket. Way out of my price bracket. Does anyone have a similar problem. Help please. Thanks for any help, this one maybe a major problem.
old person is offline
post #2 of 8 (permalink) Old Apr 20th, 17, 04:04 AM
Bob
camarocards's Avatar
Re: Kick down switch
There's a number of switches listed on eBay which may be in your price range...
camaro kickdown switch | eBay
Bob
'68 Camaro SS 396/325
'00 Vette - 350/345 Convertible, 6 speed
camarocards is offline
post #3 of 8 (permalink) Old Apr 20th, 17, 07:02 AM Thread Starter
Frank
Thanks bob i need the type that was on the 396/325 or 359 hp model it is the style that mounts to the carb with a small bracket. The bracket is is out there it is the switch i will need thanks again
post #4 of 8 (permalink) Old Apr 20th, 17, 08:20 AM
Old Dad's 67 is offline
post #5 of 8 (permalink) Old Apr 20th, 17, 09:14 AM
Chet
Go to the local pick and pull or reg scrap yard and get a switch from any of the millions of cars, trucks or vans that ran a Turbo 400 and get the switch. Truck or van will be easier. They are rebuildable. BangShift.com BangShift Tech: How to Repair the Kickdown Switch in a Turbo 400 Transmission - BangShift.com
Heartbeat City has original switches with the bracket for Holley carbs for $395
69 SS clone, fathom green, TMI sport seats, 200r4, 3.42 posi rear end, IROC steering box, SPC control arms, koni shocks.. Future mods include bolting on the Profiler heads, FIRST TPI, and roller cam sitting in the garage
onefiness is offline
post #6 of 8 (permalink) Old Apr 20th, 17, 04:43 PM
There are always a few of them on ebay:
Kick Down switch Turbo 400 1967 1968 1969 Chevelle Camaro Nova Impala 325 Hp 396 | eBay
Beware that they might be a little "sticky" from the grease they used in them getting old and hard. You can open them up with a chisel on the sides of the case where they are crimped. Clean out the old grease and use a little dielectric grease to lube. Will be good as new.
68 Camaro (Resto in Progress)
ChevyCam is offline
post #7 of 8 (permalink) Old Apr 20th, 17, 05:36 PM Thread Starter
Frank
thanks for the replies I will check with the sources I forgot to tell everyone that the carb is a rochester and the engine is 396/325 hp. thanks again
post #8 of 8 (permalink) Old Apr 20th, 17, 05:43 PM Thread Starter
Frank
thanks for the replies I will check with the sources I forgot to tell everyone that the carb is a rochester and the engine is 396/325 hp. thanks again. Just found one hope it is for real.
Human Verification
