Powerglide Slipping - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 8th, 05, 08:11 PM Thread Starter
Powerglide Slipping
I have a 1968 Chevy Impala with a 307 and a Powerglide. Recently the transmission started slipping so I changed the oil. When I removed the drain plug thick black oil came out. So at this point I wondered does transmission oil become tick and black after 37 years? or were the previous owners stupid enough to put motor oil in the transmission?
After I changed the oil and the filter the slipping improved but did not go away. So now I'm wondering is the transmission shot? or is the problem something simple like tightening the band?
If the problem is a band adjustment how do I adjust it and what tools do I need?
saeger is offline
post #2 of 4 (permalink) Old Nov 9th, 05, 01:58 PM Thread Starter
Re: Powerglide Slipping
help
saeger is offline
post #3 of 4 (permalink) Old Nov 9th, 05, 02:20 PM
thick black trans fluid is very not normal.
I would take it to a quick lube that has a power flusher. When you drain the pan, there's still about twice that much fluid in the torque converter, gonna take some flushing to get it all out. Then keep your fingers crossed that no real damage was done.
post #4 of 4 (permalink) Old Nov 12th, 05, 09:16 AM
Probably beyone a band adjustment. They are not hard to overhaul! Pull it out, and I will gladly help move you through a checkout and rebuild via here, email, or phone!
Oldani Motorsports
Oldani Motorsports is offline
Human Verification
PowerGlide Trany - Beginning of the end? mattalin Transmission & Driveline 2 Aug 6th, 05 01:33 AM
Slipping Powerglide jvenice Troubleshooting 3 Dec 15th, 01 07:22 AM
Please help me out! Swap from powerglide to TH350? 1968camaro123 Engine 14 Jul 27th, 01 11:44 AM
Powerglide to TH350 Questions... Chris Edwards Engine 4 Sep 7th, 00 04:35 PM
Speedometer gears - Powerglide vs Turbro-hydramatic g5067 Troubleshooting 11 May 15th, 00 03:10 PM
