Main case#3925656
Extension#3925658 Side cover#6261886 also has a date 11-13-78 or 11-13-70 hard to make out
Main drive gear has three rings
# stamped on machine surface R9A26
on bottom of main case has HS stamped in white letters
Orange paint on top of front bearing retainer
Lime green paint on bottom of front bearing retainer
Orange paint on extension in middle of it
Blue paint by speedo drive
I bought a RSSS 1969 camaro and this transmission can with it. But the firewall has ahole for the speedo cable to go through like a 4 speed muncie with the clips.This car was built 11c.Is it possible that this car can with a saginaw 4-speed ? It also can with a 350 300 h.p. Please help thanks
