Radiator distance from core support - Page 3 - Team Camaro Tech
post #31 of 42 (permalink) Old Jan 10th, 17, 03:55 PM Thread Starter
Re: Radiator distance from core support
Originally Posted by Vega$69 View Post
How much was the Coldcase?
Do you have BBC or SBC?
Auto or manual tranny?
AC or no AC?
$369
BBC
MT
No AC
Thanks, Jim
4Speed67CamaroRS is offline
post #32 of 42 (permalink) Old Jan 10th, 17, 04:01 PM
Vega$69's Avatar
$329.99 with Free Shipping
BeCool makes a good radiator
https://www.summitracing.com/parts/b...t/model/camaro
Vega$69 is offline
post #33 of 42 (permalink) Old Jan 10th, 17, 07:23 PM
Darin
The griffin exact fit might be the one you want,not direct fit.
Although my direct fit with dual fans couldn't fit any closer to the support than it already does,it's just about touching.
1968 Butternut Coupe,
TKO 600
9" narrowed 3"
421" Dart SHP block.
3" drop front and back.
ilikeike is offline
post #34 of 42 (permalink) Old Jan 11th, 17, 10:26 AM Thread Starter
Am I making a big ta-do about nothing? Is this an acceptable distance. Finally home from work and got some pics of it on the car and it's actual distance.
What say you?
Thanks, Jim
ID:	171282   Click image for larger version
post #35 of 42 (permalink) Old Jan 11th, 17, 11:23 AM
Vega$69's Avatar
The distance from the core support is not the issue. How far is the fan from the radiator?
Will you be able to install the factory fan shroud? I'm thinking no.
You may have to change the fan spacer for clearance. You will also most likely need to fab up for the shroud
Vega$69 is offline
post #36 of 42 (permalink) Old Jan 11th, 17, 12:03 PM
It seems that direct fit means the holes line up and exact fit means the holes line up and it is correctly spaced from the core support. At least this is my suspicion....
1969 Camaro vert LS3 4L65E Ridetech level 2
1969 Camaro project
1970 Z28 project - sold
1968 Firebird project
1969 Z28 factory air project
dhutton is online now
post #37 of 42 (permalink) Old Jan 11th, 17, 01:29 PM Thread Starter
What gets me is that the guy from Cold Case swears the spacing is accurate Obviously it's not or I just got a bad one.
Thanks, Jim
post #38 of 42 (permalink) Old Jan 11th, 17, 02:07 PM
Thanks, Jim
What did he model it after? Might not have been an original radiator.
1969 Camaro project
post #39 of 42 (permalink) Old Jan 11th, 17, 03:19 PM Thread Starter
They seem to believe they DID model it after an original. It'll be going back because of the damage it arrived with but now I need to decide whether to have them send me another undamaged one or just a refund.
post #40 of 42 (permalink) Old Jan 11th, 17, 03:30 PM Thread Starter
I will have to change the fan spacer. I have a two inch spacer that gives me about 3" from the blades to the belts but that now is about 1/2" too long. I'm not sure if they make them but I could run a 1 1/4" spacer and still have over 2" blades to belts and clear the radiator as well... I think.
How far off the radiator does the fan shroud go?
The radiator comes with fan shroud holders at the bottom of the radiator. Not sure what would need fabrication. It's supposed to accept a stock fan shroud.
Thanks, Jim
post #41 of 42 (permalink) Old Jan 11th, 17, 04:03 PM
Vega$69's Avatar
Thanks, Jim
Here is a pic of the factory fan shroud installed. The bracket that attaches the fan shroud to the radiator support will not not reach the hole in the top center on the shroud if the radiator is too far away from the radiator support.
Guess won't know until you try
69 Z28
69 LS7/T56 Pro Tour #2(BUILDING)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #42 of 42 (permalink) Old Jan 12th, 17, 02:10 PM
Rod
I have a Be-Cool rad with electric fans and it sits about an inch back from the main core support.
Sent from my SM-G935F using Tapatalk
ragtook riches is offline
Human Verification
