Best upgrade for better cooling in AZ? - Team Camaro Tech
 2Likes
  • 1 Post By ImmDanny
  • 1 Post By arocars
post #1 of 11 (permalink) Old Mar 18th, 17, 11:20 PM Thread Starter
Danny
So I live in Phoenix AZ and if any of you don't know it gets hot in the summer. I still like to drive the car around but I'm afraid of overheating when in slower traffic due to it being 100+ degrees out. Right now I have stock radiator and clutch fan and shroud. What would be my best option to amp it up a little? Bigger radiator? Duel electric fans? The engine is a 350 in case that makes a difference. Pretty stock car so Im assuming it makes whatever horsepower those made when they came out.
VitaminC likes this.
ImmDanny is offline
post #2 of 11 (permalink) Old Mar 19th, 17, 04:45 AM
Chet
Re: Best upgrade for better cooling in AZ?
NOTHING. Make sure that what you have is in tip top shape. The factory designed cooling system is the best there is, especially for a stock 350. Have a radiator shop make sure your radiator core is free flowing and not stopped up. Make sure your clutch fan clutch is functioning. That is it.
69 SS clone, fathom green, TMI sport seats, 200r4, 3.42 posi rear end, IROC steering box, SPC control arms, koni shocks.. Future mods include bolting on the Profiler heads, FIRST TPI, and roller cam sitting in the garage
onefiness is offline
post #3 of 11 (permalink) Old Mar 19th, 17, 04:49 AM
kevin
it does heat up, OR you'r afraid it might
if it is an original radiator have it rodded and cleaned
when in slow traffic keep as much space between you and the car in front as possible
sound track of my 68 383
flat tire is offline
post #4 of 11 (permalink) Old Mar 19th, 17, 05:54 AM
Might opt for a two or three row flat tube aluminium with your fan clutch and shroud.
TC # 349
zdld17 is offline
post #5 of 11 (permalink) Old Mar 19th, 17, 06:13 AM
Matt
An aluminum radiator is the easiest and best single upgrade that you can make to improve your cooling.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is online now
post #6 of 11 (permalink) Old Mar 19th, 17, 07:21 AM
Bill
x3. Keep your original radiator configuration.
1968RallySport likes this.
arocars is offline
post #7 of 11 (permalink) Old Mar 19th, 17, 07:27 AM
X4 Make sure you steer away from those off shore radiators. I recommend Enthropy, as I have had one over 5 years trouble free but I do feel Griffin is the best. Enthropy was or still is a TC sponsor .
TC # 349
zdld17 is offline
post #8 of 11 (permalink) Old Mar 19th, 17, 08:35 AM Thread Starter
Danny
The radiator is fairly new only a few years old at this point so it should be running at 100%.
ImmDanny is offline
post #9 of 11 (permalink) Old Mar 19th, 17, 08:37 AM Thread Starter
Danny
Well what is too hot? I don't like when it goes above 180. But sometimes if I have been driving for a while and then hit traffic it can go just a little past 200.
ImmDanny is offline
post #10 of 11 (permalink) Old Mar 19th, 17, 12:22 PM
Jack
My old 406 would hover around 200 in traffic in the phx summer heat. Never boiled over though. That was with clutch fan, stock shroud and a griffin alum radiator. I know someone in Phx you could talk to on that, shoot me a pm and I'll get you his contact info.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #11 of 11 (permalink) Old Mar 20th, 17, 06:39 AM
click's Avatar
Dont over fill that radiator either, there should be a small bump our line in the metal, down inside the opening below the cap, dont fill above that line at all. These are closed systems and the fluid needs space in the system to expand when it gets hot. By staying below that line, your fluid can get warm but still do its job nicely. No need for fancy 'upgrades' unless you are rebuilding the engine into a power house. We drove our Camaro on several 2500 mile round trips, then local short trips, never overheated. Modern systems have 'catch cans' or 'overfill' buckets. Our Camaros dont have that type of system.
click is offline
Human Verification
