"Basics of Basics" Pump/motor disassembly and rebuild. - Page 3 - Team Camaro Tech
Convertibles Convertible Q&A's
post #31 of 41 (permalink) Old Oct 7th, 12, 07:45 AM
Re: "Basics of Basics" Pump/motor disassembly and rebuild.
I rebuild one of these motors on my 68 Camaro years ago using the Body by Fisher manual.
Your photos should be a great help for people in the future.
I really, really wish I had known about the paperclip trick.
I remember that was the hardest thing, trying to get those bushings to stay back while putting the armature back into position. I think I remember trying to use some needle nose pliers, or tape, or something. It wasn’t easy.
327!275hp!Convt! is offline
post #32 of 41 (permalink) Old Oct 7th, 12, 09:06 AM Thread Starter
The bummer is in the manual there is nothing about the motor part. It shows how the pump works, it shows everything in the pump but nothing in the motor, it doesn't even show the armature seal.
You know what's funny is I personally came back to this thread to see how it goes together yesterday.
1965 Buick Gran Sport Convertible
1948 Chevy pickup.
2003 Dodge Caravan
1959 Rambler American (Yeah I said RAMBLER, you want to make something of it punk?)
"Fan of most anything that moves human beings"
MARTINSR is offline
post #33 of 41 (permalink) Old Apr 28th, 13, 04:02 PM
Greg
Since this thread covers a leaking cylinder, I'll post up my finding.
My passenger side started leaking heavily in the 'down' position, so I took the top O ring out to replace.
The size is 3/8" ID and 1/2" OD nitrile.
I already had a large O ring kit with 200 sizes.
It stopped leaking immediately with this simple fix.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #34 of 41 (permalink) Old Jul 17th, 14, 09:18 AM
Tony
Hmmm, what I am taking away from this thread is that it is very easy to rebuild the pump EXCEPT for the part where you have to destroy the little star gear which does not come in the rebuild kits...So..no solution to this problem? I'm very appreciative for this information but it looks like unless you have spare parts lying about, then this is not going to work..?
Tony
Follow my current Camaro project builds...
1967 Coupe
1968 Convertible
1969 Convertible
bondora68 is offline
post #35 of 41 (permalink) Old Jul 17th, 14, 10:06 AM
Sounds like it may be possible to remove the "gerotor" as John referred to it, without destroying it. If it gets some abrasions on it, they can be deburred, apparently, and it will still function. Just so I'm clear, is that outer ring supposed to move freely, or is it a press fit and the inner "gear" rotates inside of it? Does it have to be removed?
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
RSSSfanatic is offline
post #36 of 41 (permalink) Old Jul 17th, 14, 10:07 AM
Brian, how is your top motor hanging in there? Any more leaks?
post #37 of 41 (permalink) Old Oct 14th, 14, 08:24 PM
Chuck
Can someone tell me if the motor can be replaced on the power top motor? my pump is good....motor got wet....any suggestions? Thanks....
blueZ is offline
post #38 of 41 (permalink) Old Oct 14th, 14, 08:28 PM Thread Starter
I'm sorry I never answered this, not a single problem.
1948 Chevy pickup.
2003 Dodge Caravan
MARTINSR is offline
post #39 of 41 (permalink) Old Oct 14th, 14, 08:29 PM Thread Starter
These things are indestructible, I find it hard to believe that getting it wet could "kill" it. Pull it apart and clean it up, I would bet it will work again.
1948 Chevy pickup.
2003 Dodge Caravan
MARTINSR is offline
post #40 of 41 (permalink) Old Oct 14th, 14, 09:02 PM
Chuck
its had water sitting in it and the brush plate is in bad shape....I am in hopes to rebuild the motor end of it or buy a clean original from a member here.....
blueZ is offline
post #41 of 41 (permalink) Old Jan 10th, 16, 05:20 PM
While working on my top cylinders, my pump/motor started dragging. Charged battery to make sure it was all the way up, but no help. Pulled my top motor and pump apart and it is surprisingly clean inside. No gunk, and gerator and ring came right out with no problem. Going to clean contact points as described by John, ordered o-ring kit from Camaro Central, and I'll put it back together this week to see what I have.
Thinking about installing a relay to help save the switch and hopefully make the motor work better. Also thinking about trying to replace seal/o-ring on leaking top cylinder, but afraid it won't last because I could see some pitting on the ram when it is extended. Doubtful that this could be sanded / polished out. Wouldn't have much to lose if it doesn't work.
Human Verification
