What's the best waty to cut braided stainless fuel line????????? - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 19 (permalink) Old Jun 8th, 07, 11:34 AM Thread Starter
Davie
Question What's the best waty to cut braided stainless fuel line?????????
Whats the best way to cut braided stainless fuel line?
Davie T.
1968 Viper Red Camaro Z28 Clone
I NEVER wake up grouchy, I ALWAYS let HER sleep!!!!!!!!!
Maro68 is offline
post #2 of 19 (permalink) Old Jun 8th, 07, 11:38 AM
Andy
Re: What's the best waty to cut braided stainless fuel line?????????
Wrap tightly with electrical tape where you want to cut and then cut with a thin wheel on a die grinder.
Some say it is also good to bend the line in a "U" where you are cutting as you are cutting it, but I have not personally tried that.
amartinson is offline
post #3 of 19 (permalink) Old Jun 8th, 07, 11:43 AM
Thumbs up Re: What's the best waty to cut braided stainless fuel line?????????
Yep.
68 convertible 327 Ralley Green, White top, Deluxe Ivory interior, powerglide with white bumblebee stripe
bdzee is offline
post #4 of 19 (permalink) Old Jun 8th, 07, 12:02 PM
I use cable cutters. Easy to use and don't have the debris associated with a cutoff wheel. Wrap some tape around the tube and cut it with one quick motion.
onovakind67 is offline
post #5 of 19 (permalink) Old Jun 8th, 07, 12:46 PM
Jake-68's rule
Beg, borrow, steal, or buy a cable cutter as nova suggested. Then go buy & wear a pair of leather gloves.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
post #6 of 19 (permalink) Old Jun 8th, 07, 02:20 PM
gramps68's Avatar
I have done this with much success! Makes a clean cut, but I ran out of electrical tape and used athletic tape...the type you wrap ankles and knees with. Worked great and did not leave too much fraying of the hose end.
Anything worth doing is worth overdoing...a little's good, more's better, and too much is just enough
68 rs - Van Nuys original - one family car.....which still needs to be finished!
gramps68 is offline
post #7 of 19 (permalink) Old Jun 8th, 07, 02:30 PM
If you use a cutting wheel you must flush thoroughly and dry the lines with lots of filtered compressed air to assure all of the abrasive, stainless steel slivers and burnt rubber are not going to be ingested by the engine or get into any mechanism (fuel pump, power steering pump, front pump if using on an automatic for cooling lines).
Cable cutters are much better. By the way Mechanics synthetic leather gloves offer little to no protection from the frayed wire ends. You will need some good flexible (kidd) leather gloves.
Larger Dave
Larger Dave is online now
post #8 of 19 (permalink) Old Jun 8th, 07, 07:40 PM Thread Starter
Davie
Thanks for the info. cable cutters it shall be!!!!!!!!!!!!!!!!
Davie T.
Maro68 is offline
post #9 of 19 (permalink) Old Jun 12th, 07, 08:10 AM
Wrap it tape as the others suggested and use a 32 tooth bladed hack saw.
Old Man is offline
post #10 of 19 (permalink) Old Jun 12th, 07, 08:39 AM
You can also wrap the end with electrical tape and use a large chisel (like the ones used for cutting landscaping stones). Place the hose on a solid surface and give the chisel a good "whack". By far, this is the one of the quickest ways to do it and it cuts the hose and steel braid cleanly without fraying the ends.
I've never used the cable cutters, but I'm sure that they would work well too.
cowboybob is offline
post #11 of 19 (permalink) Old Jun 12th, 07, 09:06 AM
Another advantage of the cable cutters...I've never smashed my thumb with them.
post #12 of 19 (permalink) Old Jun 12th, 07, 12:35 PM
Fred
The guys here said last winter to use the Summit braided steel hose cutter. It works up to -12 AN. No tape required. Ends are clean and ready for the fitting. Just mark with a Sharpie and castrate,,er, sorry. Too long around horses!
Anyway, I bought one. The guys were right. The worlds most perfect tool. But there's a problem. I can't seem to stop looking for new places to install AN stuff.
128.79mph 1.428 60'
Fred Ficarra is offline
post #13 of 19 (permalink) Old Jun 12th, 07, 12:51 PM
Todd
TSTONE's Avatar
tape like everyone says then i've always used tin snips
Classic's only cost alot if you add up how much you spend
TSTONE is offline
post #14 of 19 (permalink) Old Jun 12th, 07, 01:15 PM
Bill
A dremel tool with one of their small cut-off wheels also works great if you don't want to buy a specialized cable cutter tool that you will possibly hardly ever use. (not that I object to having too many tools) Yes, definitely flush it out with lots of carb cleaner afterword.
68RS-SS is offline
post #15 of 19 (permalink) Old Jun 12th, 07, 05:59 PM
Den
DenRS's Avatar
I knew I wouldn't be making a ton of lines, so I couldn't justify the cutting tool. I ended up making a jig out of a old 16 inch 2x4. Right in the middle of the 2x4, I cut a slot in the one side on the 2x4about half way through. Then I drilled 8 holes for zip ties. I zip tied the hose onto the block of wood. The zip ties need to be really tight. Before I zip tied the hose, I put tape on the hose and placed it over the slot I cut out. Worked pretty good. Make sure you have plenty of zip ties.
DenRS is online now
Human Verification
1/4 fuel line. ace's68 Performance 6 Jul 10th, 06 07:19 PM
Fuel line shakes powerplay Engine 1 Mar 18th, 04 02:18 AM
fuel line . what fitting do i need? Marc Engine 3 Dec 27th, 02 11:47 AM
Steel vs. Rubber fuel line englemac Engine 6 Oct 15th, 01 09:18 PM
