Replacing Ignition Cylinder - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 27 (permalink) Old Nov 4th, 08, 07:19 PM Thread Starter
JIm
How difficult is it to replace the ignition cylinder? How would I do this?
jmkiv1515 is offline
post #2 of 27 (permalink) Old Nov 4th, 08, 07:58 PM
Jake-68's rule
Re: Replacing Ignition Cylinder
Year of car?
Tumbler replacement? Have key?
Is the electrical portion needing replacement or just the tumbler(lock cylinder)?
Give a man a rescued dog for the health of both their souls.
'With age comes wisdom, but then wisdom ages you even more.'
CUBS - 2016 World Series Champions
post #3 of 27 (permalink) Old Nov 4th, 08, 08:01 PM Thread Starter
JIm
It is for a 68 Convertible Camaro. The car did not have the keys when I bought it, so I am just replacing the ignition cylinder. I bought keys and a new ignition cylinder from NPD.
post #4 of 27 (permalink) Old Nov 4th, 08, 08:01 PM
I suspect that you want to replace your ignition lock cylinder. Up until 1969 they were mounted in the dash. You need a paper clip and your ignition key to remove the cylinder from the instrument cluster (1967-1968).
From 1969 forward they were installed in the head of the steering column. What year vehicle? If you have a column mounted cylinder, do you have a standard (non-adjustable) steering column or a tilt? You will need a few more tools to remove the steering wheel, hub, and locking plate. More complete information is available at www.corvettefaq.com in the A&F-Car Steering Papers section.
JIML82
JIML82 is offline
post #5 of 27 (permalink) Old Nov 4th, 08, 08:06 PM Thread Starter
JIm
Thank you, it is a 68 Camaro, I do not have the keys for it. That was the only issue when I bought it.
post #6 of 27 (permalink) Old Nov 4th, 08, 08:09 PM
Jake-68's rule
Okay, no key so you will need a set of locksmith tools to set the tumbler and the anvil to turn the cylinder once they are set.
As Jim said, use a paper clip and push into the hole and at the same time, turn the cylinder to ACC and the lock cylinder will unscrew out if its body.
Reassemble with the new cylinder and key in reverse without the paper clip, or with the paper clip.
post #7 of 27 (permalink) Old Nov 5th, 08, 11:10 AM
Andy
Send a message via AIM to 67SS&99SS
Or you can remove the bezel on the dash that holds the cylinder/ignition swith assembly unplug the switch and remove it from the car. Replace them both at once and you won't have to worry about picking a lock. I've tried doing this before and I don't have the patience to mess with it. I think you can get both parts for less than $40.
lock cylinder
http://www.partsamerica.com/ProductD...pe=521&PTSet=A
switch
http://www.partsamerica.com/ProductD...pe=410&PTSet=A
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #8 of 27 (permalink) Old Nov 5th, 08, 06:02 PM Thread Starter
JIm
I appreciate all of the feedback. I will more than likely just buy the ignition switch as well. It sounds as if it will be much easier to do it this way. I am not sure if I have the patience to go through picking the lock as it seems tedious. Thanks again for all of the feedback. I will let you know how it goes.
post #9 of 27 (permalink) Old Nov 5th, 08, 07:19 PM
Jake-68's rule
If I remember correctly, you have to remove the tumbler first to remove the bezel nut to remove the switch from the dash.
post #10 of 27 (permalink) Old Nov 5th, 08, 07:32 PM
Ed
You may want to try an old key for 68's. Sometimes those switches are worn to the point that another key can work. If so, you can use the key with the paper clip to remove the cyl.
Eddie M
69 Camaro Z/28
enio45 is offline
post #11 of 27 (permalink) Old Nov 5th, 08, 08:19 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
A nail file worked on my old '67
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #12 of 27 (permalink) Old Nov 6th, 08, 04:48 AM
I found this information in one of my files. It came from a very knowledgeable engineer so I am pretty sure it is correct.
REMOVING INSTRUMENT PANEL MOUNTED IGNITION LOCK CYLINDER - WITHOUT A KEY - (REQUIRES A NEW LOCK CYLINDER)
Take a 1/8" bit and drill to the side of the key slot (the side with more space). Drill about one inch deep. This will make the lock mechanism no longer functional. You should now be able to turn the lock cylinder without a key. Turn it back a click, insert a paper clip in the little hole and the lock cylinder will slide right out! AFter cleaning out the metal shavings, insert the new lock cylinder. Task complete.
Good luck,
JIML82 is offline
post #13 of 27 (permalink) Old Nov 6th, 08, 06:35 AM
I replaced the cyliner only on my car. I did have the key but I am not sure if you actually need to turn the barrel once you have the paper clip inserted. I think that if you can find a gm key that will fit in the ignition but not turn I think it will work.
I did it a couple of years ago on my 68 and I can't remember if I had to turn it or not.
The barrel was very loose and sometimes would not start the car. With the new barrel in the old switch it worked perfectly.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #14 of 27 (permalink) Old Nov 6th, 08, 06:39 AM
Take one of the door locks to a locksmith and have a key made.
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
post #15 of 27 (permalink) Old Nov 6th, 08, 07:27 PM Thread Starter
JIm
Thanks a bunch everyone, I really appreciate it. I feel a bit more confident with everyone's feedback that I can get this out. Thanks again.
Human Verification
