My camel hump heads - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 27 (permalink) Old Apr 27th, 09, 03:49 PM Thread Starter
Deanne
Send a message via Yahoo to bluchevygrl69
Question My camel hump heads
Hi all,
I have a 1978 Z28 camaro that I am in the middle of restoring.. This car is sweet. I have the build sheet found it behind the rear seat.. It is in great condition too. I bought a 350 race engine with camel hump 202?? heads.. the heads don't have holes for the air and power steering pullies.. I just know all of you know about this ,but was a huge suprise to me and now I need the coolest,cheapest,fast fix as I want to keep these heads!!!!
bluchevygrl69 is offline
post #2 of 27 (permalink) Old Apr 27th, 09, 04:14 PM
Jason
Gambitt's Avatar
Send a message via MSN to Gambitt
Re: My camel hump heads
The cheapest fix would probably be to buy a new set of heads...I have been through a similar situation and that is eventually what I ended up doing. New vortec heads are cheap and powerful.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #3 of 27 (permalink) Old Apr 27th, 09, 04:36 PM
Not going to be easy.
Like Gambitt said, the cheapest and easiest way is late model heads.
Otherwise You will have to search for a combination of brackets and pulleys for a short water pump. And even then, some of those brackets mounted to the stock intake manifold and the stock exhaust manifolds.
Bill
18436527 is offline
post #4 of 27 (permalink) Old Apr 27th, 09, 04:57 PM
Jerry R.
jr68's Avatar
drill and tap the heads so you can attach the brackets.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #5 of 27 (permalink) Old Apr 27th, 09, 05:30 PM
I had a machine shop drill accessory holes before. It was no big deal to them.
Melrose RS is offline
post #6 of 27 (permalink) Old Apr 27th, 09, 05:33 PM
scblucam's Avatar
Since the heads are not machined flat you will need to shim the brackets after drilling
scblucam is offline
post #7 of 27 (permalink) Old Apr 27th, 09, 05:48 PM
Vintage 68's Avatar
Wink Re: My camel hump heads
It becomes a 'big' deal the minute you hit the water jacket though
The heads are also not thick enough to sustain the bolt threads over the long run, the factory castings were reinforced in this area to allow the heads to carry the fasteners and loads.
There are several small serpentine belt systems that only use the water pump and lower water pump / block holes.
One of these set-ups would allow you to retain the heads.
Here is one example - http://www.dunebuggy.com/shop/index....urnTo=FEATURED
You can also use the March #22020 system and the optional #20122 rear mount bracket for the alternator for use with heads without bolt holes.
The system will run @$500~600 depending on where you get it.
So obviously, the good advice given above - about just changing to a good set of later heads - would run about the same $$$ by the time you're done...
Hope this helps:
1968 Convertible
Some trucks
Vintage 68 is offline
post #8 of 27 (permalink) Old Apr 27th, 09, 05:55 PM
Banned
Ron
Badbird's Avatar
Sorry, but these humper heads cannot be drilled for accessories, way too risky to even attempt!.....I'm afraid you'll need a new set of aftermarket cylinder heads!
Badbird is offline
post #9 of 27 (permalink) Old Apr 27th, 09, 06:13 PM Thread Starter
Deanne
so tell me about these vortech heads???
post #10 of 27 (permalink) Old Apr 27th, 09, 06:20 PM
Banned
Ron
Badbird's Avatar
You must remember, this type of cylinder head will require a different intake manifold and valve covers, maybe more....
Badbird is offline
post #11 of 27 (permalink) Old Apr 27th, 09, 06:23 PM
Patrick
This is what I did with mine.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/8-7.6sec@88mph,1/4-12.1@110mph,Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #12 of 27 (permalink) Old Apr 27th, 09, 06:26 PM
Shawn
meh, i wouldnt get them, you can get a much better set out there
victimizati0n is offline
post #13 of 27 (permalink) Old Apr 27th, 09, 06:41 PM
Jason
Gambitt's Avatar
True, there are other alternatives. Any good modern set of cast iron or aluminum heads would be great. I did forget that I had to buy an intake and new valve covers. Probably buying a new set of traditional heads you can use your existing parts with would be the best option. Summit racing and Jegs both carry these heads. Expect to spend $500 and up on a new set of heads, but that is still better than having an old set reworked.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #14 of 27 (permalink) Old Apr 27th, 09, 06:54 PM
Talking Re: My camel hump heads
I am not sure what the '78 Camaro needs for accessory holes, but my '69, only needed one bolt hole drilled and tapped for the alternator. This was done in '99 and is still holding. I doubt water is anywhere near this one hole.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #15 of 27 (permalink) Old Apr 27th, 09, 07:03 PM
You jogged my memory. Same case as mine.
Human Verification
