A.i.r. Exhaust manifold plugs - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 14 (permalink) Old Sep 11th, 10, 02:43 PM Thread Starter
Pete
What type of plug bolt was used to plug A.I.R. holes on non A.I.R. equipped 68 small blocks? Square head, hex head??
pjbizjak is offline
post #2 of 14 (permalink) Old Sep 11th, 10, 11:28 PM
Garth
Re: A.i.r. Exhaust manifold plugs
Well, I maybe be wrong, but don't believe the plugs are a factory item.... Non A.I.R. engines used different manifolds (no holes).
I'd say the plugs are aftermarket or maybe dealer ?? installed, so why does it matter what type of head is used ?
Please don't say "bad answer".....
Garfields Maro is offline
post #3 of 14 (permalink) Old Sep 12th, 10, 12:37 AM
i've used 1/4" pipe plugs- yes, the threads are wrong, but they work..
you don't plan sincerity.
novaderrik is offline
post #4 of 14 (permalink) Old Sep 12th, 10, 12:59 AM
Doug
I've used square head plugs before but as Maro stated the non A.I.R engines didn't have holes in the exhaust manifolds.
Doug
1969 Van Nuys RS Z/28. Protect-o-plate and chassis broadcast copy. Hugger Orange, original 711 interior, including carpet. Original drivetrain: DZ, M-20, 3:73 BO code peg leg. Flat hood, no spoilers.
z28doug is offline
post #5 of 14 (permalink) Old Sep 14th, 10, 09:25 AM Thread Starter
Pete
A.I.R. plugs
What type of blots were used to plug AIR holes in exhaust manifolds?
pjbizjak is offline
post #6 of 14 (permalink) Old Sep 14th, 10, 03:09 PM
Garth
Re: A.I.R. plugs
Some had square heads (most common), others were hex head.
post #7 of 14 (permalink) Old Sep 14th, 10, 06:20 PM
JohnZ's Avatar
Re: A.I.R. plugs
All '68-'69 small-blocks with manual transmissions used A.I.R. systems, except those for overseas export with RPO KD1, Less Air Injection. Those units used hex-head 1/4"-18 National Straight Pipe Thread plugs, P/N 3889330, for the holes in the exhaust manifolds.
JohnZ
CRG
'69 Z/28 Fathom Green
JohnZ is offline
post #8 of 14 (permalink) Old Sep 14th, 10, 07:00 PM
JohnZ's Avatar
See your other thread in this section and the same thread you posted on the CRG Forum.
JohnZ
CRG
JohnZ is offline
post #9 of 14 (permalink) Old Sep 15th, 10, 08:55 AM
Moderator .. Jim
click's Avatar
try to stick to your own threads and not start new ones on the same topic, its easier for folks to follow up with you in one thread.
click is offline
post #10 of 14 (permalink) Old Sep 15th, 10, 11:33 AM Thread Starter
Pete
Sorry for the duplicate threads. Well I'm mistaken, I thought only the 'LOS' built Z/28's had the AIR system and not the NOR built cars? I bought my 68 Z 2nd hand in 1970 and there was no smog equipment on it and the exhaust manifolds had the plugs in them, so now I need to find 68 smog equipment parts, CRAP!
Once again my apologies.
pjbizjak is offline
post #11 of 14 (permalink) Old Sep 16th, 10, 09:26 AM
JohnZ's Avatar
Nope. Read this:
http://www.camaros.org/emissions.shtml
JohnZ
CRG
JohnZ is offline
post #12 of 14 (permalink) Old Sep 16th, 10, 04:38 PM Thread Starter
Pete
Thanks JohnZ, I looked at CRG but missed that. Any markings on a 68 Z that tells it was an overseas unit?
pjbizjak is offline
post #13 of 14 (permalink) Old Sep 16th, 10, 04:57 PM
Lang
Same here.Just buy "Brass" and use a good Anti-Seize compound.
Ideas are like children: there are none so wonderful as your own.
langss is offline
post #14 of 14 (permalink) Old Sep 16th, 10, 06:05 PM
Gary
It was common back then to remove the smog system to increase horsepower. Some did it the same day they brought the car home. A buddy bought a 69Z from the original owner, and got several boxes of take-offs in the deal. The smog was removed the first week the guy had the car.
Unreal is offline
Human Verification
