Go Big block? - Page 2 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #16 of 35 (permalink) Old Sep 3rd, 12, 04:55 PM
Paul
Re: Go Big block?
Originally Posted by reddize View Post
If you have power steering; you might have to go to 9" brake booster instead of the stock 11"...
I think they are confusing powersteering with powerbrakes??
1969 RS/SS DROPTOP is offline
post #17 of 35 (permalink) Old Nov 8th, 12, 10:47 PM
Pete
Re: Go Big block?
In my opinion the big block is a big fat pig of an engine. Our old camaros already have almost 60% of the weight over the front wheels.
Keep it a small block and take the money you'd spend getting the big block to work and add more parts to make more power.
Pete
1968 Camaro
2003 Boxster S
Pete68 is offline
post #18 of 35 (permalink) Old Nov 9th, 12, 08:35 AM
Michael
Re: Go Big block?
...big block is a big fat pig of an engine...
Thats what aluminum heads are for.
A BB+Muncie in a first gen Camaro is a religious experience.
mahunt is offline
post #19 of 35 (permalink) Old Nov 9th, 12, 06:58 PM
keith
Re: Go Big block?
I put a 396 in a 69 a while back. Not hard. Yes the heater core needs to be replaced "comes out of box instead of firewall" motormounts, fanshroud, cross member, and had to get a smaller crank pulley.My exhaust manifold was real close to the power steering box, so I went with headers. Valve covers were stock with a small notch or dent in the rear. I also had to replace my firewall due to an flywheel coming threw it. Not good almost lost a foot.
X-77 keith is offline
post #20 of 35 (permalink) Old Nov 9th, 12, 08:17 PM
Rodney
Re: Go Big block?
I think he meant power brakes
Rodney Colbert 70 Chevelle SS Real L-78 4-speeed 68 Camaro RS/SS 350HP 396 400 turbo red with black top red interior AC PS PB 12 bolt posi #s Matching
67 Malibu ragtop 327/glide
7DL78 is offline
post #21 of 35 (permalink) Old Nov 11th, 12, 11:46 AM
Fred
Re: Go Big block?
And also with a TH400.
128.79mph 1.428 60'
Fred Ficarra is offline
post #22 of 35 (permalink) Old Nov 11th, 12, 12:00 PM
Bryon
bcm66's Avatar
Re: Go Big block?
Whoa!
Obviously you have never ridden in one that will pull the front wheels off the ground at take off.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #23 of 35 (permalink) Old Nov 11th, 12, 12:56 PM
Re: Go Big block?
When I put a BBC in my 67 I sold all of my SBC stuff.
Like stated, 1st time I got on it it was a religious experience: Damn near enough torque to counter rotate the Earth...
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline
post #24 of 35 (permalink) Old Nov 11th, 12, 01:55 PM
Fred
Re: Go Big block?
Originally Posted by bcm66 View Post
Whoa!
For sure. My 67 BBC innards (bought it in 68 so as to have a 427 in my later purchased 69) pulls the wheels on nearly every run. And that's with the original drive train. (sorta) The 300' time slip clockings equal 0-60 mph at 2.44 SECONDS. Pig big blocks
128.79mph 1.428 60'
post #25 of 35 (permalink) Old Nov 12th, 12, 08:39 AM
Michael
Re: Go Big block?
I think Pete refers "pig" to handling (he lists a panty Porsch among his rides).
Not to worry Pete, with alum heads, Muncie, headers, 'glass hood and a few of Dave Pozzi's handling recommendations; I'm sure something can be done to make a BB first gen agreeable to someone like you.
mahunt is offline
post #26 of 35 (permalink) Old Nov 12th, 12, 08:48 AM
Bryon
bcm66's Avatar
Re: Go Big block?
Well this is what he typed. I can't say what he meant.
CRG -
bcm66 is offline
post #27 of 35 (permalink) Old Nov 12th, 12, 04:28 PM
Gary
Re: Go Big block?
Nothing like that "fat pig of an engine!"
Unreal is offline
post #28 of 35 (permalink) Old Nov 12th, 12, 05:30 PM Thread Starter
Re: Go Big block?
Well it is in a 454 supposed to be about 600 hp. not all hooked up yet. but in and ready to send it in for paint.
Tpls6Tate is offline
post #29 of 35 (permalink) Old Nov 12th, 12, 05:47 PM
Bryan
Re: Go Big block?
First, you need to jettison the Camero and get a Camaro. Next, get a good Camaro parts catalog with a highlighter and a note book. Highlight and write out all the BB parts and you'll quickly see there are a lot of minor differences: Clutch linkage, cross member, frame/motor stands, radiator, radiator shroud, heater core, heater core cover, carburetor linkage, fuel lines (possibly)..... that's what I can think of without scratching my head and leafing through a parts catalog. If you do it, do it right. They are too old, cool and people make special trips to look at them so don't do a circa 1980's teenage hack job. Besides, a hack job causes a lot of headaches and tweeking that'll make you wish you had just swapped the right stuff out.
CPT Chevy is offline
post #30 of 35 (permalink) Old Nov 12th, 12, 07:20 PM Thread Starter
Re: Go Big block?
Cross member,linkage,mounts,heater core and cover are all switched out.Taking it slow and trying to do it RIGHT. also Have corrected my spelling error
Human Verification
