Custom Sequential Turn Signals - Page 2 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 4Likes
post #16 of 99 (permalink) Old Mar 4th, 14, 11:51 AM
Re: Custom Sequential Turn Signals
Do you have any pics of the Mounting? how did you mount the plastic block to the housing?
67 Camaro LS1+ tvs2300/4L70E 530 RWHP
64 Corvette Coupe 350/ TKO600
66 Mustang (289/C4)
c6matt is offline
post #17 of 99 (permalink) Old Mar 6th, 14, 11:31 PM
Thanks jusy bought everything to do this just what i need another project
Sent from my SGH-T759 using Tapatalk 2
'00 Sierra ext. cab 5.3l intake best run 15.89
2000 grand prix GTP
cjrolke is offline
post #18 of 99 (permalink) Old Mar 7th, 14, 04:33 PM
do you have any more pics of how they are mounted in the tail lights?
thanks
2000 grand prix GTP
cjrolke is offline
post #19 of 99 (permalink) Old Mar 10th, 14, 10:41 AM
Rich
this is great info I'm wanting to do this on my 69 bird and the Digitails are just too pricey IMO I know LED lights are cheap and run mostly on 12V i just hadnt made the time to do the research Thanks Tmax68! I just ordered the parts and if no one else post up a how to with pics I will when I do mine. a sticky for all LED upgrades would be nice - how about it Mod?
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
69 Nova SS retirement project
99 Firehawk
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #20 of 99 (permalink) Old Mar 20th, 14, 05:52 PM
Got my leds yesterday still waiting on the relays and flashers
2000 grand prix GTP
cjrolke is offline
post #21 of 99 (permalink) Old Mar 26th, 14, 05:00 AM
Still waiting on my diodes, but the housings are done..these panels are BRIGHT! I never got an answer on red or clear leds above, so I went with clear.
using a 12x12 sheet of ABS plastic off of amazon, I made brackets.
The panels were perfect size for the housing.
I used a hole saw to make grommets for the wires and to seal the housing
Winning.
I had initially made a panel that put the panels really close to the stock lens, and you could count the LEDS using bright spots, setting them back deeper in the housing gave it a much better look IMO
66 Mustang (289/C4)
c6matt is offline
post #22 of 99 (permalink) Old Mar 28th, 14, 05:00 AM
i like the idea of the brackets
I am still waiting on the relays
I did go with the red leds so we can see the difference
I will get pictures as I am going with mine
what was the thickness of the plastic you used?
thanks
2000 grand prix GTP
cjrolke is offline
post #23 of 99 (permalink) Old Mar 29th, 14, 07:35 PM
Wel i got them built have to get the brains in the boxes and do the final hookup to the car but i like it
ID:	68882   Click image for larger version
2000 grand prix GTP
cjrolke is offline
post #24 of 99 (permalink) Old Mar 30th, 14, 06:05 PM
got everything installed today
http://youtu.be/HpxuV4kx45o
only one problem that I ran into was I cut loose the old tail light plugs and my car was a standard car at one point.
we when I resoldered the connections I hooked it up and could not get the passenger side to work tried everything possible
short version is I hooked up the wire to damn reverse light wire on that side
in my defense one wire is light green and the other is medium green
oh well live and learn
2000 grand prix GTP
cjrolke is offline
post #25 of 99 (permalink) Old Apr 1st, 14, 08:59 AM
Rich
Anyway to do something similar with a non-RS tail lights?
Thanks,
Rich
1967 SS350, Under construction.
H20cooled is offline
post #26 of 99 (permalink) Old Apr 1st, 14, 04:16 PM
The led panels fit into the housing you would have to find shorter versions of the panels and the have everything combined together
2000 grand prix GTP
cjrolke is offline
post #27 of 99 (permalink) Old Apr 6th, 14, 12:12 PM
Brandon
Sweet, cool mod. So for a '69 base coupe could you use the same process?
'69 coupe, 350 engine and trans, HEI Dist, headers, posi-track. It's a good 15 footer
withac is offline
post #28 of 99 (permalink) Old Apr 6th, 14, 02:16 PM
Brandon
Originally Posted by tmax68 View Post
Here's the Ebay links for the parts (hope its okay to link them here)
12V Delay Relay
12V Piranha LED Panels
Electronic Flasher
I'm looking at your parts list and diagram, where does the flasher go?
withac is offline
post #29 of 99 (permalink) Old Apr 6th, 14, 06:35 PM
pretty much
mounting would be different
2000 grand prix GTP
cjrolke is offline
post #30 of 99 (permalink) Old Apr 6th, 14, 06:38 PM
one would go under the dash in the fuse block the other under the dash where the second flasher is
you have to ground the 3rd prong on each flasher as well
here is a better video of my setup
http://youtu.be/9OUE5DE2ds4
2000 grand prix GTP
cjrolke is offline
Human Verification
