Custom Sequential Turn Signals - Page 4 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #46 of 99 (permalink) Old Apr 9th, 14, 05:55 AM
Re: Custom Sequential Turn Signals
Originally Posted by withac View Post
Yeah, I think that's what ill do.
Thanks for all the feedback and helping me understand the whole process.
no problem
'00 Sierra ext. cab 5.3l intake best run 15.89
2000 grand prix GTP
cjrolke is offline
post #47 of 99 (permalink) Old Apr 9th, 14, 12:38 PM
Brandon
Iím back, hopefully with my last question. The listing for the flasher has ended but there are a bunch of others, all with a different ending number. The one you list ends in EP98, I canít find any that end in that. There a bunch that look the same but there are several different ending numbers. Do you know if that matters?
'69 coupe, 350 engine and trans, HEI Dist, headers, posi-track. It's a good 15 footer
withac is offline
post #48 of 99 (permalink) Old Apr 10th, 14, 10:16 AM
this should work
http://www.ebay.com/itm/3-Pin-hot-sa...0bf8f1&vxp=mtr
2000 grand prix GTP
cjrolke is offline
post #49 of 99 (permalink) Old Apr 10th, 14, 10:18 AM
Brandon
Ok, thanks, they all looked the same I just didn't know if those last numbers and letters made any distinction in the function.
I appreciate the time.
withac is offline
post #50 of 99 (permalink) Old Apr 11th, 14, 01:15 PM
Brandon
I took my tail light housing apart, things will fit, this is doable. I did find that the silver paint on the inside around the bulbs that is supposed to reflect the light is flaking badly. When I do the mod I plan on cleaning it up and painting it. I’m wondering about what will work the best, silver like it is, white, or you can even get spray paint that is supposed to look like chrome. What are your thoughts on what would reflect the best?
withac is offline
post #51 of 99 (permalink) Old Apr 11th, 14, 08:47 PM
Really it shouldnt matter as led lights are directional you will want to have the panels aiming out the lenses
Sent from my SGH-T759 using Tapatalk 2
2000 grand prix GTP
cjrolke is offline
post #52 of 99 (permalink) Old Apr 11th, 14, 08:53 PM
Brandon
Guess you're right they aren't like a bulb with a 360 degree light emission. Thanks.
withac is offline
post #53 of 99 (permalink) Old Apr 12th, 14, 10:00 AM
Brandon
Originally Posted by cjrolke View Post
one would go under the dash in the fuse block the other under the dash where the second flasher is
you have to ground the 3rd prong on each flasher as well
here is a better video of my setup
http://youtu.be/9OUE5DE2ds4
I assume when you say third prong you mean the one that is perpendicular to the other two that are across from each other?
withac is offline
post #54 of 99 (permalink) Old Apr 12th, 14, 04:11 PM
Brandon
Nope, never mind, I just found a spare flasher and can see which is the extra prong.
withac is offline
post #55 of 99 (permalink) Old Apr 12th, 14, 04:12 PM
I will have to look at mine but i believe it is one pin marked g but i will have to double check i googled how to wire the 3pin flasher
2000 grand prix GTP
cjrolke is offline
post #56 of 99 (permalink) Old Apr 12th, 14, 04:14 PM
Brandon
I found a two pin flasher so I was assuming I plug in the same two the ground the third
withac is offline
post #57 of 99 (permalink) Old Apr 12th, 14, 07:33 PM
yes
2000 grand prix GTP
cjrolke is offline
post #58 of 99 (permalink) Old Apr 20th, 14, 03:57 PM
Brandon
Well, got the delays and LED panels and flashers ordered. Looks like they are literally coming on the slow boat from China, should be here in three to four weeks.
withac is offline
post #59 of 99 (permalink) Old Apr 20th, 14, 05:31 PM
Yea they take a while to get there but it is worth the time for these results
2000 grand prix GTP
cjrolke is offline
post #60 of 99 (permalink) Old Apr 24th, 14, 11:53 AM
Jason
blue89bird's Avatar
anyone want to post how they mounted the resisters/diodes? Did you just solder them right to the light panel and put them behind the LED panel inside the housing or somewhere else? Did you use any shrink tubing or anything on top of them?
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
Human Verification
