Custom Sequential Turn Signals - Page 5 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 4Likes
post #61 of 99 (permalink) Old Apr 24th, 14, 10:56 AM
Brandon
Re: Custom Sequential Turn Signals
Haven't done mine yet but will post pics when I do. I planned on soldering the resisters and diodes inline with the wiring away from the panels then putting shrink tubing around them.
'69 coupe, 350 engine and trans, HEI Dist, headers, posi-track. It's a good 15 footer
withac is offline
post #62 of 99 (permalink) Old Apr 25th, 14, 11:48 AM
I have mine soldered inline and everything is in some project boxes I bought at radio shack the boxes have 2 wires that are soldered to the cars harness and then the feed to the tail lights is ran through a 4 wire trailer connector to each housing (for removal if needed)
'00 Sierra ext. cab 5.3l intake best run 15.89
2000 grand prix GTP
cjrolke is offline
post #63 of 99 (permalink) Old Apr 26th, 14, 01:45 PM
Chris
jumpstart's Avatar
Looking forward to doing this mod as well. The rest of my parts must be on the same slow boat from China though. Couple more weeks.
1969 X44, 355 SBC, BDS 6-71 blower, dual Eddy carbs, TCI Streetfighter TH350, 4000 stall, Denny's driveshaft, 10-bolt 8.5 rear w/4.56 gears, Caltracs, M&H drag radials, 10 point cage
jumpstart is offline
post #64 of 99 (permalink) Old Apr 30th, 14, 02:49 PM
Brad
I just ordered all the pieces thru amazon for this project, but with a slight twist I ordered these
http://www.amazon.com/dp/B0094GKSBC/ref=pe_385040_30332190_TE_3p_M3T1_ST1_dp_1to try and make sequential taillights in a standard (non RS) 68. My plan is to put 2 of these in the taillight housing and make them sequential. Then obviously 1 wide strip in the back up light housing. Even from amazon there is month delivery time. I will update as I go.
68 Camaro, HOT LS3, tremec 6 speed, vintage air, 17 inch tourque thrust II, CPP discs, 3.73 posi, Autometer gauges, painless harness
Brad74 is offline
post #65 of 99 (permalink) Old May 13th, 14, 02:39 PM
Brad
OK I have all the parts and I have mocked this up . I think it will work. I do have a problem with the flasher. I have an aftermarket wiring harness with only 1 flasher. The fuse block is a round hole, but the new flasher is square. I might have to take some plastic off of the fuse block, but I really dont want to go throught the hassle of removing it. Is there a round LED flasher?
Also, I understand I have to gorund the new LED flasher. but the ground prong on the new flasher will not match up with the hole on the fuse block so I can ground it. In other words the only way it wil fit into the fuse block (assuming the square peg will fit into the round hole), the ground is in a female attachment in the block, rather than the hole so I can gound it. anybosy else with this problem
Brad74 is offline
post #66 of 99 (permalink) Old May 13th, 14, 02:42 PM
Brandon
I got my parts yesterday too. I haven't messed with the flashers yet but figured the third prong might be an issue. Later tonight if I have time I'll take a look at mine and see what I'm in for.
withac is offline
post #67 of 99 (permalink) Old May 13th, 14, 02:59 PM
Brad
I found this
http://www.amazon.com/Terminal-Signal-Flasher-Switch-Electronic/dp/B004O1YTLW/ref=lh_ni_t?ie=UTF8&psc=1&smid=AB2D0HPKF1X8Dwhich is the same thing digitails sells for about $10 less.
Brad74 is offline
post #68 of 99 (permalink) Old May 13th, 14, 07:05 PM
Brandon
Ok, on my 69 I one under dash which is a two plug right angle socket, the three pronged flasher fits just fine. The one on my fuse box on the firewall the flasher socket is on the corner and flush so no problem there. My only question is which plug do o ground, I'm assuming the one marked negative (-)
withac is offline
post #69 of 99 (permalink) Old May 18th, 14, 02:52 PM
Brandon
HELP
Ok, I wired everything up like the diagram earlier in this thread. I only did the left side.
1) When I put my test light on the contacts on the right side of the delay relay, the bottom connection where the yellow wire connects is dead. The middle one with blue jumper wire and the top empty slot blink but there is no delay.
2) On the left side of the delay by the top inside and bottom inside corner of the green connector box is a little LED. The bottom one is marked ground and blinks with the
blinkers. The top one never lights up.
3) When I turn on the left blinker it blinks solo. When I turn on the right blinker the left one blinks too. After a few steady but dimmer blinks on the left, the blink will flicker or stutter, then go back to a rhythmic blink for a few cycles.
4) when I step on the brakes the brake lights come on, after a few seconds the outside section on the ones I'm working with goes out, there is a click in the delay relay, and a little read LED in the middle of the delay relay comes on. If let off the brake and step on it again it comes back on and does the same thing.
5) I replaced the flashers with the LED compatible ones. The one under the dash that runs the turn signals clicks continuously when the key is turned. The lights don't blink, but the flasher clicks. I swapped it with the one on the firewall fuse panel to see if I had a bad flasher. Nope, either one clicks continuously when plugged into the turn signal connection.
I guess there are two possibilities, bad delay relay or more likely I've wired something wrong.
Ideas?
withac is offline
post #70 of 99 (permalink) Old May 18th, 14, 04:20 PM
Brandon
I went ahead and swapped delay relays. Still the same. I swapped the blinker flasher that clicks whenever the key is on for the stock flasher. It doesn't click but everything else is the same.
withac is offline
post #71 of 99 (permalink) Old May 18th, 14, 04:35 PM
When i did mine i did everything outside of the car it was easier. verify all your connections and try it that way
Sent from my SGH-T759 using Tapatalk 2
2000 grand prix GTP
cjrolke is offline
post #72 of 99 (permalink) Old May 18th, 14, 06:01 PM
Brandon
Thanks. Yeah, I did the same thing. At first I had some common grounds and wondered if I was getting current feedback and that's what made the left blink with the right so I separated all the grounds but it still does it. Weird they the left blinks alone but the right lights up the left too.
withac is offline
post #73 of 99 (permalink) Old May 18th, 14, 06:18 PM
check your diodes make sure they are going the right way
2000 grand prix GTP
cjrolke is offline
post #74 of 99 (permalink) Old May 18th, 14, 06:22 PM
Brandon
In the picture it looks like the silver band is towards the LED's, right?
withac is offline
post #75 of 99 (permalink) Old May 19th, 14, 06:04 AM
Brandon
Update
Went out this morning to see if the front left turn signal blinked with the right like the rear. The left rear didn't blink with the right anymore. It didn't blink sequentially, but it didn't blink with the right. Good news. So I tried the brake lights, same thing as yesterday after a few seconds the outside section on the left kicked off. Tried the turn signals again, now the left is blinking with the right. The front work like they should.
withac is offline
Human Verification
