Battery that works perfect with R59 delco battery cover - Page 2 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #16 of 21 (permalink) Old Feb 20th, 16, 03:08 PM
Rick
Re: Battery that works perfect with R59 delco battery cover
Is there more than one brand of topper?
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #17 of 21 (permalink) Old Feb 21st, 16, 02:41 AM
69-Pace's Avatar
I don't think so.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #18 of 21 (permalink) Old Feb 27th, 16, 07:25 PM
Rick
Anybody know if this Bosch will work? 24-710BAGM
Anybody?
I ended up using a NAPA 7524 which looked identical to an Interstate MT-24 only the case was already black. Fit perfectly. No modifications.
Last edited by 69-Pace; Feb 28th, 16 at 09:39 AM. Reason: no need for three merged into one
rp930 is offline
post #19 of 21 (permalink) Old Feb 28th, 16, 05:12 PM
Darrell
cook_dw's Avatar
I modified my topper to fit the terminals, made the eye look real and drilled the other caps to look the part as well.. Actual battery is a O'Reilly's 24 series Super Start.
Darrell Cook
1967 LeMans Blue SS/RS L35 - clone, fake or whatever you wanna call it. Its not original
1968 Rallye Green SS L78 - original unrestored
1968 Matador Red Z28 - undergoing restoration
cook_dw is offline
post #20 of 21 (permalink) Old Feb 28th, 16, 07:23 PM
Brett
Man that looks cool.
RS1979 is offline
post #21 of 21 (permalink) Old Feb 28th, 16, 08:47 PM
Rick
I redid the "eye" also.
rp930 is offline
Human Verification
