Turn signal issue - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 8 (permalink) Old Feb 16th, 17, 05:59 AM Thread Starter
Carl
Turn signal issue
Old issue here, but this seems unique; Left turn signal light stays solid, does not blink; right is ok, emergency flashers working fine, new bulbs, ground at radiator bracket is good, sockets look perfect. Was working fine a few days ago. Could the issue be in the steering column?
Carl Shelton is offline
post #2 of 8 (permalink) Old Feb 16th, 17, 07:19 AM
69-Pace's Avatar
Re: Turn signal issue
A simple test is to swap the flasher units between signals and flashers. If the problem stops when the flasher unit is in the signal socket it is a bad flasher unit. If the problem stays it could be the turn signal switch, or a few other items but start with the easy diagnostic. Also check the wiring connection on the steering column commonly called the harmonica for a loose connection.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 8 (permalink) Old Feb 16th, 17, 07:45 AM Thread Starter
Carl
Thanks...I'll give those tips a try.
post #4 of 8 (permalink) Old Feb 16th, 17, 07:49 AM
Nick
I had a the same issue on my right turn signal but only when my headlights were on. I had other strange issues also. Everything was resolved by fixing several ground wire issues.
Nicc21 is online now
post #5 of 8 (permalink) Old Feb 17th, 17, 10:16 AM
Larry
I wonder if the bulbs could be in backwards. When you press the brake pedal, is the brake light filament actually the one that's on? Same with the turn signal. If the tail light and/or the parking light filaments are the ones that are burning instead of the turn signal/brake filaments I could see how the amperage possibly might not be enough to get the flasher to start.
Current Project:
66 Chevy C10 Resto-Mod
Next In Line: 69 Z/28 Resto-Mod
69-er is offline
post #6 of 8 (permalink) Old Feb 17th, 17, 01:23 PM
69-Pace's Avatar
Yes could also be ground issues but I like to start the diagnostic flow with the less complicated easy tests and the most common causes.
69-Pace is offline
post #7 of 8 (permalink) Old Feb 17th, 17, 03:04 PM
Jake-68's rule
The only difference between emerg flashers and turn signals is power source.
Each circuit, including brakes, have their own power from fuse panel.
Emerg & turn are the same after turn signal switch - same wiring.
I would check bulbs for correct install and the correct filament lighting, as suggested, and replace turn signal flasher with a 552 flasher.
A 512 relies on power drawn to flash whereas a 552 does not care, can handle up to 6 bulbs.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
post #8 of 8 (permalink) Old Feb 17th, 17, 06:35 PM
R/T
Jack
Check the wire connector(turn signal light) in the left front fender. Might be loose..
Matthew 22: 37-39
R/T is online now
Human Verification
